Question about Brother MFC 420CN All-In-One InkJet Printer
Not printing red or yellow even after new cartrige
3 Suggested Answers
  • 526 Answers
SOURCE: no yellow color no test printing
take the cartridge out and look at the area that the sensor checks, and see if you see a lot of ink. it will be clear tube and you should see the ink, if it looks full, then your nozzles that go to the printhead either have air in it or the printhead is clogged up.
try doing up to 5 cleanings, and do a test print, check the nozzle test print everytime, if you do not see an improvement, then most likely the printhead will need to get replaced.
thanks adi
Posted on Dec 13, 2009
Jimsta01
  • 405 Answers
SOURCE: My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Posted on Apr 06, 2010
The red color is not printing and the yellow is very light. with a new cartrige
Try removing your color cartridge and you shake it vigorously, if this persists, try a re-fill.
Jan 07, 2011 | Canon MultiPASS MP390 All-In-One InkJet...
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
My pictures turn red
generally this is due to your ink cartrige not having enough of the cyan or yellow to produce accurate colors. that or the print heads need to be cleaned on the cartrige. you can clean them with a cotton swab and some rubbing alcohol.
if all else fails replace yoru color cartrige with a new one.
Feb 12, 2010 | Lexmark X1240 All-In-One InkJet Printer
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
MY RED IS EMPTY,BUT ALL THE REST ARE FULL, HOW CAN I USE MY PRINTER, I AM IN THE MIDDLE OF A PROJECT, IT'S 5AM AND I CANT PURCHASE A CARTRAGE, PLEASE TELL ME HOW TO CONTINUE IN JUST BLACK? ( EMERGENCY...
Hi I am Vortash check your settings in the printers utillities , there should be a setting to turn off colour production , the other alternative is to fool the printer , ?. If your head unit is the same as my Brother unit then it has seperate colour cartriges Magenta , Cyan , Yellow , and a seperate black .. simply make a small hole in the top of the Magenta/red cartrige and fill with water .. then cover the hole with a little tape or some type of sealant .. this will make the printer belive you have a fresh cartridge and continue printing .. you may even find that the red will be although weak will be present ?. hope this is of help regrads Vortash
Jul 07, 2009 | Brother MFC-3360C All-In-One InkJet...
My printer again skips lines when I print. Also there is no red even after changing cartriges. It will print without skipping in the highest quality mode, but still no red. Several months ago you sent me a...
try replacing the other cartridges, I had the same problem except the printer auto printed red, the problem was that it only allowed me to print some colors because the other ones were empty.
Cheers
Jun 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer Cartrige Problem [Tri-Color]
if the printer queue is empty and you have turned both comp and printer to off it should reset.
Frpm your explanation it sounds like your color cartridge has a problem Tricolor red,blue, yellow maybe one is empty the black is a separate cartridge
Jun 21, 2009 | HP J4680 Office Jet All-In-One Printer
Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
Jun 02, 2008 | Lexmark X83 All-In-One InkJet Printer
Print Out
yes replace the cartridge it appears the cartrige is defective
Dec 06, 2007 | Dell 924 All-in-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
120 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
