Question about Samsung RB1955VQ Bottom Freezer Refrigerator
The top refridgerator is not cooling correctly
The top refridgerator is not cooling correctly and the temperature will not adjust
  • Samsung Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fgmjfd
Posted on Sep 29, 2010
I just bought this refridgerator which was a floor model. The lights are working but it doesn't seem to be cooling. The display also shows the temperature to be 0 F for both the freezer and...
It's in demo mode which allows the store to have the interior lights and display illuminated without wasting energy on cooling an empty unit.
To switch this off, hold the Energy Saver and Adjust Freezer buttons simultaneously for about 3 seconds.
Hope this helps. If you need further assistance, please let me know.
Regards,
BElectric
Jul 29, 2011 | GE PFSS6PKSS
How should I set the temperature. The refridgerator and freezer is not able to maintain a consistent temperature. What is the correct freezer and top refridgerator setting and how do I know it has accepted...
Basically the thermostat controlls the freezer temperature which turns the compressor on and off.
The refrigerator section receives cold air from the freezer to cool it down.
So when the freezer is off there may not be enough cold air left for the refrigerator.
Fridges can never give you a perfect temperature every time there will always be a drift one way or another.
Once you reset the temperature the numbers or an led should blink at you to confirm the changes you made
Mar 25, 2011 | Liebherr KGK 2833 Comfort Bottom Freezer...
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
Freezer gets cold but refridgerator does not
There is a concealed fan that is supposed to circulate air between the two compartments and normally a control that allows you to change the ratio of cooled air so the temperature can adjusted between the two compartments. This fan has likely failed.
Oct 25, 2009 | Refrigerators
The food freezes in the refridgerator section
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Jul 11, 2009 | Maytag MTB1954EE Top Freezer Refrigerator
    My Jenn-air refridgerator model JCD2389GEW is not cooling
    turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
    Jun 11, 2009 | Refrigerators
    Electronic temperature is locked
    it sounds like the main control pcb is bad. it is not letting the defrost cycle work correctly and now the damper in the refridgerator side is stuck
    May 06, 2009 | LG LSC26905TT Side by Side Refrigerator
    GE Eterna Series side x side refridgerator
    Temperature adjust displays not showing, can not adjust temp, is something disconnected?
    Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Samsung RB1955VQ Bottom Freezer Refrigerator Logo
    277 people viewed this question
    Top Samsung Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
