Question about RCA DRC220N DVD Player
RCA - Dvd - Video Cd - Cd Mp3 Decoder : Model# - DRC220N Problem - When disk is inserted, it says "Reading Disk". Then says "Incompatible Disk", Then says "No Disk".
    Novelist:
  • 133 Answers
Have you already tried to clean the laser pickup lens?
If not, then maybe you should try (there are youtube videos explaining it).
If the unit has been operating for a few years or so and if cleaning the lens doesn't solve anything, then the next most likely problem is the spindle motor which needs to be either cleaned (which is a bit difficult) or replaced (which is either less difficult than cleaning or entirely impossible). The other motor that can cause problems is the slide (laser pickup position) motor, but if the buildup of the disk mechanism makes it impossible to replace the motor(s), then unfortunately the only solution is to replace the entire disk mechanism.
regards
Triarcuate
Posted on Sep 29, 2009
Testimonial: "I found that if i opened the top and applied pressure to the top of the cd as its trying to be read by the laser it plays fine w/o being exposed 2radi"
  • 4L60B4R1UM Oct 01, 2009
    Hi, your testimonial suggests another possible cause and that is a loose flat cable connection either on the laser pickup assembly or the one that goes from the tray mechanism to the electronic circuit board (laser and data cables), possibly also on any of the other connectors that link the disk tray unit to the electronics (door motor, spindle motor and pickup slide motor cables - these are usually made with stacks of separate wires).
    Try to disconnect and reconnect these connectors at each side, one by one, and see if there's any improvement. Take care when you do it with the flat foil cables to avoid damaging them. Also, the flat cables usually have a lock mechanism on the connector to keep the cable in place. The connector is made of whitish plastic while the lock on it is of a brownish colour. There are two types of locks - the ones that need to be slided in the direction of the cable to release the cable and the ones that need to be lifted to a right angle from the cable to free the cable. I've mostly seen the latter type in the laptops so i think there will be the ones that slide to unlock in your unit (some types will have no locks so the flat cable is simply pulled out or pushed into the **** on the connector)..
    When you disconnect a flat foil cable, see if the bare contact tabs at the end of the cable have dark(ish) areas in the places where the connector pins touch them when the cable is locked in place. If there are any darkened spots on these tabs, they need to be cleaned gently with a sharp tool, a pointed scalpel for example (don't scrap them hard, just so that the dark areas are shiny again). The darkened areas are oxydized and are therefore a possible loose connection point on a flat foil cable which might be causing unit malfunction.
    Also check the motor connectors on the tray unit, they are usually a thru-hole connectors soldered to a piece of curcuit board - see if any of the connector pins are loosely soldered to the board and resolder them if necessary.
    Thanks for your testimonial.
    regards
    Triarcuate
Just bought an Ematic 1.5%22 Color 4GB MP3/4 Video Player and the driver disk it came with about 3'' wide much smaller than a std cd so i cant use it. where can i get the driver and anything else to make...
You should be able to use the small diameter disk. The disk can be inserted in the CD/DVD drive just like a normal size CD/DVD disk, it locks onto the spindle on the laptop's CD/DVD drive. The laser reads from the center of the disk.
Oct 16, 2009 | Dell Inspiron 1501 Notebook
CD IS READING BUT DVD NOT READING IN ASUS COMBO DVD
Try to clean you combo drive using disk cleaner. Also if you don't have disk cleaner then you can but it in the video and computer shop. Then try to insert another new cd to test if it really works after you clean the combo drive.
Thanks
Aug 03, 2009 | Computers & Internet
Cd- rom is not reading DVD movies
It may be that you don't have a DVD Decoder program installed. Look at the disks that came with the computer and see if one of them needs to be installed. The disk should be printed with information as to what is on the disk.
Thanks for using Fixya.com
Harleyknut.
Apr 08, 2009 | Dell Dimension 2400 PC Desktop
My DVD not reading DVD movie CD
Is it not reading the disk or not playing DVD movies? If you put a DVD data disk and it reads, then the drive is fine. If it just wont play movies, youre missing a DVD decoder (such as PowerDVD). Try testing other DVD disks and post your findings.
Mar 06, 2009 | Computers & Internet
It dosn't read the dvd
DVD/CD drive is bad.
As a general rule, the CD/DVD drive cleaning disks do nothing but attempt to scratch the lens by brushing off dust.
Mar 05, 2009 | RCA RTD300 DVD/VCR Home Theatre System...
Disk is inserted yet message says no disk inserted
If the DVD is not reading any CD, or DVD, then it is often a lens problem.
Try first cleaning lens with a lens cleaner DVD, possibly one with cleaning solution, that can be purchased at any computer & electronics shop.
If that does not work the unit must be taken apart, to clean the lens pickup with isopropyl alcohol and soft cotton tips.
If this happens only with a single DVD , then the disk is dirty , scratched or defective, or , if it is blank the unit does not like the particular brand.
Dec 31, 2008 | RCA DRC105N DVD Player
Insert a disk
How many CDROm drive installed on your PC? The message appear when you burn a CD or just only reading the content?
Mar 02, 2008 | Samsung SM 352 CD-RW/DVD-ROM Burner
RCA DRC220N DVD Player Logo
151 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
