Question about 2wire 2700HG-B Router (2700HGB)
I have a 2wire 2701HG-B
I am trying to forward a port but I cant access my router I tried typing in the i p address but to no avail . i am trying to open the port for utorrent because my download speed is so damn slow with out the port forwarded.
I would really appreciate it ty.
  • 3 more comments
  • dagamer Mar 03, 2008
    trying to play medal of honor rising sun and the game is telling me to forward port 28500 to a different ip adress ...how???
  • roseph Apr 13, 2008
    im trying to download world of warcraft 10-day trial version so i can play on private servers and i have all the wrong ports open and its only 3gb but my pc said it will take over 20 hours to download its been downloading for 2 hours now and it barely broke the hundred mega-bytes.
    i have tried typing in my i p address but it says "site not found"
    any help at all would be really appreciated thank you very much
  • Chris_assist Apr 26, 2008
    I cannot figure out how to forward the ports, however I can access the gateway screen
  • mikey1229787 Dec 28, 2008
    I have the same problem but cannot access the 2wire gateway site using the web address or the ip address.
  • Anonymous Jan 18, 2009
    cant access 2wire 2701HG IP address home page
In your address bar just type in "home"
Posted on Apr 02, 2011
The address of the 2 Wire is 192.168.1.254
If you're trying to access another router in your network, you need to directly connect your computer to that router and enter its address.
Posted on Nov 09, 2008
    Problem Solver:
  • 14 Answers
I access my Gateway 2701HG-B via
www.gateway.2wire.net
I use the password that I first used to register with ATT
I also can access using the password of my alt nick which i use to get EMail via Winmail or Yahoo mail.
Access via gateway. last time i checked if you do not have a good signal the DSL lite will either blink red or be solid red.... only GREEN shows you have a good signal and sync.
I still sure the master password is the number on the bottom of the Gateway. Not the SN but the next set. (per my manual)
Posted on Oct 05, 2008
Gateway.2wire.net... try that, it should work
Posted on Dec 21, 2007
I belive the default pw is your dsl tele #
Posted on Oct 26, 2008
How to open and close ports on your 2wire router for the x box 360
here's direct link on Port Forwarding
http://support.2wire.com/?page=view&article=21
there's a step by step walk through with screenshots..
hope this helps thanks roger
Aug 31, 2011 | 2wire (2701HG-B) Wireless Router
How to open port 5000 on 2wire gateway router
You will have to go to the routers web page and configure the port to be allowed to pass through. Go to 192.168.0.1 or 192.168.1.1 one of those and type in your password for the access if you did not change this it will be by default admin for username and password is admin I just type in the username admin and it opens you may have to do both username and password as admin. Once there go to port configurations and add 5000 as the port and check on both options for access.
Hope this gives you some idea on how to do this because each router is different in their page setups I cannot tell you exactly what the port configurations are but this will get you closer and others may post with further information for you so keep checking on this post. Or read help files when you arrive at the router site they are there look for port forwarding that is what you will be doing. Thanks for using FixYa! John
Apr 20, 2011 | 2wire (2701HG-B) Wireless Router
2wire 2701 block port 80
Go to the following link. This is just an example on how to forward ports for limewire. Use the same steps to forward port 80.
http://portforward.com/english/routers/port_forwarding/2wire/2701HG-B/Limewire.htm
If it still doesnt work, try updading the firmware. In case this fails, then we have some issue with the router
regards
Sandeep
Oct 13, 2009 | 2wire 2700HG-B Router (2700HGB)
Cant get to routers login screen
click on start click on run (if XP) or search (if vista) type "cmd" and hit enter u'll get a black window and in that type "ipconfig" and hit enter u'll get a list of numbers under "ethernet adapter local area connection" if its a wired connection or "wireless adapter local area connection" look for "deafault gateway" that's ur router's IP address, just type it in the address bar and bingo u'll be in ur router page.
May 14, 2009 | NetGear DG834G Router
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Can't access my DVR remotely via Video Server E
why i cant remote access my dvr in WAn but LAN is working fine?
Jan 03, 2009 | 2wire 2700HG-B Router (2700HGB)
Fix this thing before my 20 oz estwing does......
Below are some links you can check out and see if it would help you make the gaming console connect to the net behind a 2wire adsl gateway.
Nintendo Wii behind a firewall/router:
Port Forwarding on a 2wire gateway:
Nov 06, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Connecting to Ichat
Please click on this link you will find exactly what you need to do exactly(with pictures) ,,
http://portforward.com/english/routers/port_forwarding/2wire/2701HG-B/iChat.htm
Jun 05, 2008 | 2wire 2700HG-B Router (2700HGB)
Port forwarding? 2wire 2701hg-T
try the link below it may do it for you if your router is supported on the site http://www.portforward.com/
Sep 04, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
7,381 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
