Question about Zebra QL 320 Thermal Printer
When connected to an Alflex yellow stick reader the QL320 prints the barcode and visual number over 2 labels. I need to reset this so onlyuses 1 label. Help please
Barcode Print aliginment is not proper in windows7
Try a different print driver. Go to Zebra web site and download driver for Windows 7'
Apr 22, 2014 | Zebra Office Equipment & Supplies
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Dec 10, 2010 | Zebra QL 320 Thermal Printer
How can we change from black bar sensor printing to using the gap between labels on a Zebra QL320 plus?
First you need to send below file to the printer via Vista Label
Printer >> 1 Send File
Save this file as gapsen.txt:
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
To save this as default setting, send below script (save as setting.txt)
^XA ^JUS ^XZ
Nov 03, 2010 | Zebra QL 320 Thermal Printer
I have a Zebra s600 that is set to 30 darkness and the head is screwed down fairly tight. I can print this way but if the printing lightens up, I don't have any more adjustment. The barcode reader picks up...
0.print config label (printer off, press Cancel button and tur on printer, wait 5 secunds and relese button)
1.press the last button until the ligth set on Darkness (Darkness on),
2 press the 3rd button 10 times( darkness down from 30 to 20 (3rd button=less 2nd button=more),
3.press 2 times the last button untill the 3 leds flash(save)
4.turn printer off.
5.Press pouse button, turn printer on, still pressing for 8 secunds, and then release te button.
6.The printer go to print the test label, let run 3 or 5 labels, then pause.
If not happy, repeat steps 1 and 2 (less times 2 or 3 times at the time and save)
print configuration label again ans se if you happy.
If the printer still going to darkness 30, chek if you forgot to save or check the driver settings and change.
Last option Resect to Factory Defult (this drop darkness to +10)
Oct 29, 2010 | Zebra Stripe S600 Thermal Label Printer
Dear sir or mam ,i m having argox GE200 barcode printer which is not responding. when m giving print no response from the printer and any error also not showing.wat to do?
Hi.. Just follow these steps, hope this may trouble shoot your barcode printer.
1) Restart Your Computer/ Barcode Printing S/w / Barcode Printer/ and try now.
2) Even if it does not work, check the cable connectivity with printer and system
3) Even it is not working, try printer calibration or labels feed options in printers.
4) Check the proper sensor adjustments in printers,
Hopefully this should help you to get back your barcode printer online.
If you have any other queries with barcode printers, please email/contact us.
Regards Kirubakaran.Rv Web Marketing Manager Trridev Labelss Mfg Co Leading Labels Manufactures In Chennai Mobile - 96000 07995 www.trridevlabelss.com email kirubakaran.rv@gmail.com
Sep 03, 2010 | Argox OS-314 Label Printer
Powers down after every print
There is a setting in the all CPCL based Zebra mobile printers called "DTR Power Off". You will need to turn disable this. It sounds like you are printing through the serial connection based on your brief issue description.
Connect to the printer with serial cable and run the Label Vista application, free from Zebra.com. If your printer is a Q3C or Q3D configuration, you can connect with a mini USB cable, but you will have to install the driver. If you have a Q3A or Q3B configuration, you must to use the serial cable (PN: BL11757-001) to connect to your PC.
Once in Lavel Vista, click on the Printer drop down and choose the COMM Port Settings option. Select the correct value for your connection type. Next, select Printer Settings from the Printer drop down. Go over to the Port tab and click the disable button under the DTR Power Off section. Click apply. If this does not work, also check your inactivity timeout setting as well as your battery level setting in the batery tab od the same screen. I set mine to "0" because I dont want my printer turing itself off for any reason.
Apr 04, 2009 | Zebra QL320-Plus Mobile Printers QL320...
VB With MC9090S
If you are willing to use VB.NET, then it will be easy. You would need the Symbol EMDK. With that and VS2008 (Express should be fine as well), you only need few coding steps:
1) Add reference to dlls
Symbol.dll and Symbol.Barcode.Dll
2) Finder a scanner
s = Symbol.Barcode.Device.AvailableDevices.First()
3) make a reader
r = New Symbol.Barcode.Reader(s)
4) add data
d = New Symbol.Barcode.ReaderData(1, 1024)
5) enable laser
r.Actions.Enable()
6) enable reading
r.Actions.Read(nrd)
7) add handler
AddHandler r.ReadNotify, AddressOf r_ReadNotify
8) read data in event
msgbox(d.Text)
That is all there is too it. Good day.
Jan 22, 2009 | Symbol MC9090 Barcode Scanner
Z4MPlus barcode printer
I have had this problem, but only when I used a label of a size that isn't within specification. Technically, this printer isn't specified for a label that is under 1 inch in height. I have a label that is only 0.2" in height and it will get sucked down inside the machine. I have asked the people who work on the manufacturing floor to advance the label two rows after a print job so that this doesn't happen. Then I ask them to cut the label off leaving the two rows sticking out. So, the next print job will start with the label stock sticking at least 1/2 " out of the printer.
I believe that also my printer doesn't tear the labels cleanly, so there is sometimes something that can catch right at the tear bar. You can probably fix that problem if it exists for you by adjusting the tear bar, or having a machinists slightly sharpen it. I hope this helps.
Dec 27, 2007 | Zebra Z4Mplus Label Printer
Zebra QL 320 Thermal Printer Logo
69 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
