Question about LaCie Electron 19" CRT Monitor
Electron 19 blue 3 outer screen
Is there a way to replace the outer glass on the electron 19 blue 3. It was cleaned with an abrasive rag and it ruined the non glare coating. Thanks
Download this monitor test [url]http://www.iiyama.com/Download/documents/ice_pages_documents/21/MonTest_2_1.exe[/url] and click on 'convergence' Now manually change the convergence setting of your monitor with the onscreen buttons to align the red/green/blue lines
Posted on Jun 05, 2008
CDS slipping when playing.
Try the disc in another CD / DVD player.
It is important to make sure that the DVD itself is the problem, and not the CD / DVD player.
Cleaning a CD / DVD player is a much more intricate process that requires device-cleaning hardware.
Lay the disc artwork-side down so that you can easily clean the playing side.
You should always avoid setting a disc playing-side down to prolong its lifespan.
Gently rub the disc with a soft, lint-free cloth to remove all traces of dust and fingerprints. Always rub a disc from the center toward the outer rim in a light motion to prevent any other damage.
Apply a light amount of toothpaste to a cotton wool ball and gently rub the disc from the inside out.
You may need a few drops of water to make the toothpaste spread easily.
Cover the entire surface area of the disc, or at least the area that is scratched.
Toothpaste is a gentle abrasive that works well for fixing simple scratches.
Clean off the toothpaste with the cloth, once again rubbing from the inside of the disc toward the rim.
Try not to push too hard to prevent further damage.
Apply other kinds of light abrasives such as baking soda or glass cleaner if the sound is still distorted.
Remove the solution with the same gentle rubbing technique.
Purchase a disc-cleaning spray from a local video or electronics store.
These sprays are effective in removing any grime from the disc and filling small scratches.
hope this helps
Sep 30, 2012 | Philips Fwm608/12 600W Subwoofer Mini...
Pictures scan with a dark line
Hi ,
can you please specify your printer model for more appropriate solution Buddy!..Thank you!..
Jul 19, 2008 | HP Office Equipment & Supplies
Tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
Fwm608 CDS slipping when playing
hope this helps
Shark Intelligent Electronic Iron - how to clean the soleplate?
Try a "magic eraser". They're minimally abrasive. Then run the iron over a piece of waxed paper and then on a cotton cloth or rag.
Apr 26, 2010 | Euro-Pro Shark GI490 Iron
If I DO NOT want to use the self cleaning feature is there any other safe way, including using soap and water, to clean the oven without ruining it? (I don't want to use the self cleaning feature)
  1. Oven door : Wash the door and window with soap and water and rinse with clear water. Use glass cleaner only if sprayed on a cloth first. Do not use abrasive pads, powdered cleaners, or steel wool on glass and enamel, or the surfaces will be scratched.
  2. surface burner : To absorb a spill when it is hot, pour salt on it and wipe it up when the oven has cooled. A mildly abrasive baking soda and water paste can be used in the oven, too.
  3. Racks:Remove oven racks and clean them in warm, soapy water. Stubborn messes can be cleaned by using mild abrasive cleansers or a soap filled scouring pad. Rinse and dry the racks before returning them to the oven.
  4. Metal trim:Metal trim can be cleaned with glass cleaners or mild cleansers, soap and water. Abrasives or cleaners made for oven interiors should not be used.
Thanks
Smith.
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Television shuts off by itself
TRY THESE STEPS
>Check the buttons on the TV make sure they are clean and not sticking.
>Check the Remote Control buttons and see if they are sticking
>Clean the Face of the infer Red lens to the remote and the TV...
clean them with a small rag or paper towel (Do Not USE Abrasives to clean any part of your Electronics)
>Check the plug for any defects
>Reset your tv back to it,s factory settings
>And if any thing locate your user manual and find the 1-800 number
Aug 29, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Tv shuts off
TRY THESE STEPS
(please feel fry to leave a rating)
Aug 22, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Panasonic HDTV 1080i Screen
Usualy Panasonic have 3 layers on the screen. From inside to outside is: fresnel, lenticular and protective. If only the one from outside is broken don't wory. It;s just protective and the film it's just a filter to improve the black level. You can use it like that but be carrefull because the lenticular it's not protected anymore and if you scrach it ... And do not try to clean it with anything else just dry rag.
Dec 10, 2007 | Draper Replacement Surface ONLY for...
GE oven door
First, determine what this gook is. If it is grayish, it is ash and can be removed with a rag and plain water. You'll always find ash as a byproduct of the cleaning. If it seems to be oven grease and is located in the gasket or gasket area ONLY, get some WD 40 and spray it on the gunk. Let it loosen up and remove it with a rag. You may need multiple applications. If possible, follow up with a soap solution to remove as much of the WD 40 residue as possible. Note, this may cause some smoking when the oven is next cleaned. Be sure to ventilate the area well while using this or any other solvent. Do not use the solvent on glass, it may discolor when heated. Use a standard glass blue liquid glass cleaner or water. If the glass won't clean easily, you may use a WET mild abrasive pad or steel wool VERY gently...so as not to scratch the glass. Follow up with a dampened rag. Anything you leave on the glass will be baked on...so make it clean! You may also use this procedure in the gasket area on the porcelain. Porcelain is a glass-based paint. It should not be scratched. Be patient.
Be aware that if you take door apart that the door is counter balanced. Removing a significant amount of weight by taking off pieces of the assembly may cause it to slam closed. Each of the two thicknesses of glass are mounted separately. Usually, there are some kind of clips holding the glass. Note that there is often fragile insulation inside the door. Avoid touching it or breathing in any dust it may emit. You may need a second pair of hands to align the door front and the bolt holes when re-assembling.
In the future, do not wait too long between cleanings. Use a rag to remove heavy spillage as soon as you find it, don't wait for a cleaning cycle. If your oven is very dirty, use a 3 hour setting or longer to finish the job if you have goo left in your oven after the cycle.
Bob
Nov 20, 2007 | Kitchen Ranges
LaCie Electron 19" CRT Monitor Logo
381 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
