What precautions should i take before using any softwares?
  • 700 Answers
To add:
Google forums about that particular software for some backgrounds. And also read the system requirements where it will runs best. Scan the software first for any virus. And as says, create system restore points. If some problems appears you can restore it back to last good known state.
Posted on Sep 29, 2009
  • 93 Answers
Hi frnd...
* Back up the data..
* Create a system restore..
Where are the jumpers on toshiba satallite c675d s7101
https://www.youtube.com/watch?v=IkmKCFSt0pg
use esd precautions before removing memory cards unlike in the video where no esd precautions were used ,
or
try a software solution much safer to try first
https://www.youtube.com/watch?v=9aslVZsiYdw
Jun 11, 2015 | Toshiba Computers & Internet
What parts do i need to have replaced po604 internal control module random access memory (ram) error
Using ESD precautions and making sure your computer is unplugged from power, with a can of compressed air you can try dusting within the case. This may help with this error, but you may also have a stick of RAM going bad or a software driver problem also.
Aug 27, 2014 | Computers & Internet
Nokia 3110c freaquent software problem
Hi Here are some precautions. Due to 1.Using memory Card of more than 1GB(512mb is recomented by Nokia) 2.Over storage of data in Phone Memory. 3.Transfer data via Bluetooth.
All these are related to this problem.So, to avoid this you need to get rid from this mis use. Thanks for visiting fixya
Sep 12, 2011 | Cell Phones
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
Hi, I have a problem with my MSI 790GX-G65 motherboard with Phenom II 1055T processor, it will show me random bluescreens even when doing light browsing of internet or even during system is idle. Any...
This is often caused by drivers, software or hardware conflict. If possible reinstall everything even i recommend the Windows/OS. But first uninstall the suspected software and scan using an updated antivirus, clean the hardwares and motherboard. Uninstall newly added software or hardware. Restore to the previous settings when there wasn't problem. If all the precautions doesn't help, your only option is to format the system and reinstall fresh operating system. But if you can't do all these, better to let the Technician do it for you, otherwise you may make mistakes. Good luck..
May 12, 2010 | MSI AM3 790GX-G65 Motherboard for AM3/AM2+...
Authorization code anywhere anyone?
I think the best and honest answer to this would call the software company and explain the problem as best as possible. I've done it a few times myself. It is embarassing and probably awkward, but it does help. I think as a safe precaution, if you bought it from somewhere, have the reciept ready.
May 01, 2009 | Adobe Computers & Internet
When i try and load creator9 i get a message that the certificate is missing
This is a precaution that Microsoft uses to help prevent any software get loaded that could possibly harm the system or not operate properly.
If you trust the software maker, go ahead and click "continue anyway" and load the software.
I am guessing that the "creator 9" software you are loading is the Roxio Easy Media Creator 9. If so, you should not have any problems just from loading it.
I have the same software and received that same window when I loaded it, but since then I have upgraded to Creator 10 not long after that and it is much better.
As time passes and you load more and more software, you will probably see that message a few times when loading software.
it does not mean that the software is bad, just that it has not been tested by microsoft and given a certificate as being compatible with the operating system.
Just don't load any software that has come from questionable places, and it would be a good idea to scan anything you plan to use with your anti-virus software first to make sure it is clean.
If you found this information helpful, a good rating is always appreciated :)
Jun 22, 2008 | Packard Bell Computers & Internet
Safe E2
What sort of problems are you afraid of? There really aren't any viruses for the Palm that I know of. Nor any trojans.
However basic precautions would include downloading software only from trusted sites. A good place to start would be pocketgear.com (formerly palmgear.com).
Feb 14, 2008 | Palm Tungsten E2 Handheld
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
