Question about Cameras
USB Device Not Recognized, Works with Other Camera, Same USB Cable
  • 126 Answers
Looks as if the usb device of your camera? is malfunctioning. Try putting in the MMC/SD/MS Duo card into a dedicated card reader to get the pictures and videos or in the other camera.
In this instance your USB cable is the medium connecting the usb device (camera) to your pc. As the other camera and same cable are working fine this means that both the cable and your pc's usb port are working properly as well. Time for you to change the device from which you are trying to read information from.
Posted on Sep 29, 2009
    Problem Solver:
  • 5 Answers
If you have problems with your memory card in 80% of all cases the controller of your card is damaged and no software or card reader can help. You must separate the memory chip and dump the raw data to recover your data, look here: CF xD SD memory card/stick photo recovery
Posted on Oct 03, 2009
When I Connect My Aiptek 8100 camera to the PC, they show a message "USB device not recognized." Is this because I did not install it's driver? If so please tell me where I can find the driver?
Usually usb device not recognized is due to damaged usb cable or usb port..use a different usb cable and connect it to your pc, if your usb cable is ok then connect it to a different usb port. if the problem in not with the usb cable or port install driver from the cd you got with camera. if you dont have that cd download driver from the device manufacturer site.
Oct 03, 2012 | PC Mall 8100 (MODEL 8100) PC Notebook
USB Device not Recognized
The camera should have come with software which includes the correct drivers. Did you install the drivers before connecting the camera? The camera simply may not be compatible with your OS.
Sep 05, 2009 | Microsoft Windows XP Home Edition
Camera wont sync with any computers
YOU HAVE TO INSTALL DRIVER BEFORE YOU HOOK THE USB CABLE.
Jul 23, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
Feb 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
HP F2200 all in one/ usb
As you are receiving the USB device not recognized whenever you plug in the USB cable, the problem could be either due to the corrupted USB drivers on your computer or the USB cable needs to be replaced. Try updating your USB drivers and/or replace the USB cable. I am sure that the issue will be resolved.
Nov 23, 2008 | HP DeskJet F380 All-In-One Printer
Fine pix s6500 fd camera
first thing i would do would be to make sure you plug the cable first into the usb port with the camera off then turn on the camera, see if it is recognized by the computer. If not the next step is to check your usb driver to make sure it is working. Try some other usb device. If it is recognized then i would make sure you have seated the memory card properly in the camera as well as the cable. I know that sounds dumb but that little usb cable to the camera has to be well seated. You may have to update your driver for the usb port.
May 15, 2008 | Fuji FinePix S6500 Digital Camera
I cant put pictures onto computer?
you have several options.
1. see first what operating system you computer runs.
if it is vista or mac, it will be recognized as unknown device,
look for SSCAM100 or DCIM folder. you will then see the camera files in that folder.
2. you should also download the cd driver, the cd that comes with the camera, to your PC. this will help the connection be proper.
3. if you're using desktop, try to connect the camera at the back of your tower. look for a USB port at the back of the tower and connect USB cord to it.
4. make sure you're using the proper USB cable, the cable that comes with the camera. for your S630, it is USB cable type 2.
5. also, make sure before you connect camera to PC, camera is turned off, when the USB cord is properly connected, that is the time camera should be turned on.
6. when unpluggin the camera to PC, make sure that you are safely removing the device from the PC so you will not have future connection problems.
hope my suggestions work for you.
Jan 06, 2008 | Samsung Digimax S630 Digital Camera
USB device not detected
Mine does the same thing, and i have done everything to try and maake it work, but it doesnt, and it is geting me so fustrated all the time.
Aug 14, 2007 | Samsung NV3 Digital Camera
Cameras Logo
540 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
