Question about RCA Lyra RD2765 MP3 Player
The volume on MP3 play goes to mute during listening and can't get it back up. I turn the dial and the volume level doesn't show
    President:
  • 803 Answers
Try reflashing the firmware for your device you can find the latest firmware and flashing utilitys from the manufacturers website.
Make sure taht you back your music up first because when you do this you are setting it back to factory settings.
Posted on Sep 29, 2009
Why would the output sound level on a MP3 vary so much?
MP3 songs are recorded at different levels. Many modern tunes have been deliberately recorded loud by the record companies for maximum effect.
If you are recording the songs yourself some recording software has a "normalize" feature. This increases or reduces the volume of the track to a certain level. Especially useful when you have tracks at different levels. By the way this is how they get CD tracks to play at the same levels. So you don't have to turn up the volume or turn it down every time a new track plays.
Nov 11, 2017 | Audio Players & Recorders
Tip
Troubleshooting Laptop Sound Problems - No Audio Output
Symptom:
Can't hear any sound out of my laptop.
Diagnosis & Solution:
If you can't get any sound out of your laptop, the most likely cause is the volume being turned down or muted. Newer laptops monitor the external sound control so when the volume is turned up or down manually, the volume control in the operating system tracks right along with it. But with some laptops, especially those with external dial volume controls rather than toggles, the volume dials are independent of the software volume control and can't be monitored in software. In this case, if the volume dial is turned down on the outside of the laptop, the sound is turned off and nothing can be done in the operating system to change that. The only way to get the sound back is to turn up the external volume dial control.
If you have checked the external volume control on the laptop and the standard laptop volume slider in the operating system (the little speaker icon in Windows system tray) & you still can't get any sound out of the laptop, then the next step would be to check for any other software volume controls. Depending on the software installed and what you are trying to do, there may still be multiple volume controls and mixer panels scattered about the operating system. If the wrong channel is muted or turned down all the way in one of these independent controls, the laptop will not produce sound.
Most of the time, the first sign most laptop users get that their audio isn't working is the absence of operating system sounds, like the Windows rush on start up, or chimes with e-mail activity. Of course, these sounds can be turned off by design as well, through the Sounds option in Windows Control Panel. So, before looking at hardware problems, make sure these sounds are not turned off.
If you try to play an audio CD and the media player shows that the song is progressing but you can't get any sound out of the laptop speakers, odds are that the volume is turned down or muted. But it could also be due to an onboard sound hardware failure. If you are confident the volume is turned on in all possible locations and you've checked Windows Device Manager for a report of a hardware failure, try listening through headphones. If the headphones work, the wiring to the internal speakers has broken or come loose. Wiring failure is only likely if the speakers are in the lid and therefore wired through the hinges.
If you don't get any sound out of the headphones & you haven't missed a "mute" being checked off somewhere in software controls, then it really is a hardware failure. If the problem is with all sounds, including Windows chimes, internet radio, etc, then the problem is that the integrated sound processor has failed. In this case, unless the sound system is on a daughter card, it means the fix would require replacing the motherboard. But if the only thing you can't do is play audio CD's, then the problem is that the output from the DVD/CD player is muted or not getting to the amplification stage.
In modern laptops the DVD/CD players feature Digital Audio Extraction (DAE) which means that music CDs can be read digitally & the data passed to the built-in sound card or an external sound card replacement for processing, amplification then output. If there's a problem with the DVD/CD connector or if the wiring has been damaged, the music CD may get spun around without the sound making it to the sound card. The DAE output chip rarely fails on the CD/DVD drive, but the connector can fail. Make sure that digital playback is enabled in the properties tab of the drive in Device Manager.
You can replace your built-in laptop sound card with a PC card, with a USB sound card or USB speakers. These replacements make good workarounds if the integrated audio system fails. They also bring with them a whole new level of software with more volume controls, which are integrated with the existing operating system software. When shopping for replacement sound cards, keep in mind that USB solutions are much cheaper than PC cards. Also, when purchasing USB speakers to replace the laptop's sound system, don't buy speakers advertised as "USB powered". The "USB powered" speakers only draw their power from the USB port, they still need to be plugged into a regular audio jack to output any sound.
Please Vote for this Tip if you found it helpful.
M. Omran
on Nov 03, 2010 | Computers & Internet
My stereo plays but no sound
check for a mute button ,and check if volume switch displays volume increase when turning volume level up
Jan 14, 2014 | 2007 Toyota Camry Hybrid Sedan
How do you turn the volume down .
1. Turn on the cube 2. Hold silver + yellow at the same time while the startup music plays 3. At the end of the music the voice will say "volume control, volume level ..." 4. Release the buttons 5. Tap either silver or yellow, listen to the voice and it will tell you the new level, "4", "3", "2", "1", etc. Yellow goes softer to a minimum of "1", Silver goes louder to a maximum of "4". 6. When you're done, just wait a few seconds and it will automatically ask you which game you want to play.
Dec 08, 2010 | Pfizer Electronic Rubiks Cube Rubik's...
When i turn the tv on the volume is stuck all the way up and if i mute it it stays muted until you turn it off and back on
Muting is not designed to lower volume it shuts it off completely That;s why it resets when turned on and off.
Unless by muted you mean you can lower the volume to a listenable level but it reverts to full when you restart it.
Try using settings and set the volume and the type of sound(mode) you want then when you exit the menu it sshould save those settings.
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Planar XP15SSA-01 15 in. LCD Television
I have a Motorola H681 that used to work fine, now i can still pair with my iPhone, and all buttons seem to work (volume, call button) but there's no audio. During a test call the iphone shows the volume...
I was having the same problem - I ended up just playing with it until it worked again. I found instructions on muting the H700, which is to tap both volume buttons at once. I did that a few times while on a call (I was actually listening to my voicemail), and then I hit the volume up button, and now it works. Not sure if something is loose inside and all I had to to was play around to get it back into place?
Feb 17, 2010 | Motorola Mobility H681 Bluetooth Headset
Cannot listen to any sound without the ear piece
You can play it through the TV as if it was video, using the Battery Dock. Similarly, just put it through my stereo by connecting the audio cables to the AUX input (leave the Video unattached). Just remember the volume levels on the 405 need to be upped when playing through the TV and stereo and you'll probably have to turn the TV and stereo up to a lot louder than norma;when watching TV or playing a CD, so remeber to turn them down before switching back, otherwise the neighbours (or speakers) may blow.
Sep 13, 2008 | Archos 405 Digital Media Player
Ipod Nano 3rd Generation volume problems
ITunes contains a volume leveling program that works with every recording in your library or you can select each one individually by going to the library, selecting get info with the right mouse button, select options, and change the volume with the control you see on the screen and press ok.
Aug 17, 2008 | Apple iPod nano 3rd Generation
Music Player Won't Play - 'muted'
I don't think that I can suggest a precise fix for your problem. I would probably go about backing up my contacts and data. I would then 'hard reset' the phone by dialing *#7780#
Feb 05, 2008 | Nokia N95 Cellular Phone
RCA Lyra RD2765 MP3 Player Logo
137 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
