I cannot turn off my unit or make changes with the controls. I have to use the main swith to turn the unit on and off.
You may need to install a new thermostat, or it may be as simple as cleaning the end of your thermostat sensor.
Posted on Sep 29, 2009
Tv swith on and off by itself and move channels by itself
Check its main system control memory IC. If this IC is faulty, this kind of fault can occur.
May 28, 2013 | Televison & Video
AKAI LCT37Z6TA TV Issues
Sounds like the main board as it has all control and signal processing on it.
May 16, 2012 | Akai Televison & Video
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
Oct 17, 2010 | Broan-NuTone Broan 68W White Decorator...
How do I change the water level pressure switch on a Kenmore topload washer?
I believe you can remove the screws on top control unit should be 1 on each side then flip back control unit ,remove the hose ,connectors,pressure swith, i had a problem with mine and found out that the hose had fallen off quick fix!
Jan 09, 2010 | Kenmore 24032\24036 Top Load Washer
Konica minolta bizhub 162 have error C0000(main motor malfunction) i try with another motor but same thing! any ideas?!
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Nov 30, 2009 | Office Equipment & Supplies
GREEN LIGHT ON CORD COMES ON BUT THE AC UNIT WONT TURN ON. IT IS A SAMSUNG AW109CB PLEASE HELP.
you need to verify that power is getting to the control panel, the green light does'nt mean that there is power to the unit, also verify power to the controll swithes/board and verify that the thermostat is closing and trying to turn the unit on
Jul 12, 2009 | Samsung AW1203B Air Conditioner
On copier sow display bord "Swith main power off and on E001
When switch on ImageRUNNER 330s Grayscale Copier then no display on dispaly board. But Copier front yellow led is on. Please solve this problem.
May 29, 2009 | Canon ImageRUNNER 330s Copier
FT4018 RICHO PC MACHINE BREAK DOWN.
CODE #29 — LENS HOME POSITION ERROR 2
- Definition -
The lens home position sensor’s output remains HIGH (actuated) for 10
seconds after the unit leaves the home position.
- Possible Causes -
· Defective lens home position sensor
· Defective lens drive motor
· Defective main control board
· Defective lens drive mechanism
May 25, 2009 | Ricoh Office Equipment & Supplies
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
