Question about HP Pavilion dv9000z Notebook
Precautions before conducting troubleshooting
    Guru:
  • 126 Answers
At first remove the Battery before you open the Laptop. Have some any tools like screw and smoothly remove all pins and put it in one place. Also remove any plug in play device like CD/DVD Drive which is very easy to pull out.
Posted on Sep 29, 2009
Panasonic pl201 lens stuck
There are troubleshooting steps for this problem that might help you. Recommend watching the following video, and conducting the troubleshooting steps in sequence exactly as shown:
Dec 07, 2012 | Samsung Pl201 14mp Camera - Red :: 7 X...
Tip
Clothes washer fills but then stops and won't agitate or go into spin cycle!
Chances are the lid/door switch is malfunctioning. But in many cases it is the plunger that attacks the switch that has failed. Before replacing the switch, try activating the switch manually. Caution: Use a non conductive plastic item when trying to activate the switch manually. You are dealing with water and electricity at the same time. Precaution is required. Most replacement parts of this nature are between $16 - $50 and a service call requires removal of the lid and front door assemblies and in some cases more part removal. Average repair time 30 - 45 min.
on Sep 25, 2011 | GE Washing Machines
I need a schematic for a haier htq21jaaww refridgerator
I have a copy of HTQ21AAWW Service manual that include the following :
eatures, product code explanation and series introduction, specification, safety precaution, parts and functions, function schedule, system flow chart, circuit diagram, maintenance service and troubleshooting, troubleshooting and repairs.
If you want to download the copy, I'm online now at the pay question. Click here.
Jdvillanueva
Oct 03, 2011 | Haier HTQ21JABWW Top Freezer Refrigerator
Water starts to spray from the bottom of my Bosch Aquatak 120i when i turn the water on. Is it still safe to use when this is happening
Electricity and water can be a hazard which could be life threatening, but you can operate electrical equipment in a wet environment if you are careful and follow safety precautions. Most import, make sure the electrical outlet you are using for the pressure washer has a working ground plug. Just because an outlet has three prongs does not mean the ground is working. You need to use an outlet tester which is inexpensive from a hardware store or use a multi meter to test the ground for conductivity to earth ground. Your power washer should have a working GFI (Ground fault interrupter), and you need to press the test button to make sure it is working. If your power washer does not have a GFI purchase one from a hardware store. I would also plug the power washer directly into the electrical outlet since an extension cord could have a bad ground connection and will cause the power washer to pull more current from the outlet. Make sure the power washer is raised of the ground so it will not sit in a pool of water. If you follow the safety precautions you should be safe but keep in mind water does not carry the electrical current, it is the impurities in the water which carry the current. Therefore, water could be more conductive depending on the impurity of water. However, it sounds like a loose connection in the power washer which could also be an o-ring or a washer is broken and it would b a good idea to have it fixed.
Apr 29, 2011 | Garden
I want to troubleshoot my SAmsung sdi flat screen tv.
it depends on you if you can have confidence. if you have knowledge in electronics, know the safety precaution when troubleshooting then go for it.
Feb 06, 2011 | Samsung Televison & Video
Have a Sony Bravia KDL-40v4100 Flat panel, had a bad storm, lightening strike in front of house, now the tv will not turn on.
Now tv turn on?Front LCD screen panel power light indication flashes or totally dead?Yes,than the power board is dead,that the board where power a/c cord plug into it.Take the tv aparts.That the power supply board,require changing.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 27, 2010 | Sony BRAVIA KDL-46V3000 Television
LIGHTNING STRUCK THE ELECTRICAL POLE DOWN THE STREET. THERE WAS A POWER SURGE AND WHEN THE POWER RESUME THE TV DID NOT COME ON
Now ur tv LED power light indication on the front LCD panel flashes?Yes,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay,com to buy a refurbish power supply board for the replacement.
Jul 13, 2010 | Toshiba 37AV502U 37 in. LCD HDTV
After a recent lightning storm my Sony KDL32LL150 will no longer turn on, what parts should I troubleshoot and replace to attempt to fix?
Power supply will be the first place to look, most power supply will have MOVs for taking care of the small surges. The fuse may blown when the MOVs conduct to clamp down the surges or spikes.
You will have to open it up.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 02, 2010 | Sony KDL32LL150 315 in HDTV TV
Safety Inquiry
Improper use of a power inverter could result in personal injury. The inverter should not be installed in the vehicle’s engine compartment. Keep the inverter free from moisture as liquids conduct electricity, which may lead to serious damage or injury! Do not use the inverter near flammable materials or where fumes or gases may accumulate. The AC Output (neutral) wire should be vonded to ground, except in special applications. See owner’s manual for more details.
Aug 27, 2008 | Lenmar N-Verter 250 watt Maximum, 200 watt...
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
