Aqua Rite P/N 066012C-1
Did anybody have any luck getting that schematic for the Aqua Rite. My cell works but gives a low salt reading, so the system shuts off. I wanted to find a way to ''trick'' the controller into reading about 2000 ppm higher. Thanks Luc Email: lucvanmalderen@dslextreme.com
3 Suggested Answers
SOURCE: AQUA RITE P/N 066012C-1 burned controller PCB-need service manual
I have tried to get a electrical diagram but no luck. The part you are referring to is a current limiter "SL32-2R025" it is available from this website http://www.ibsstore.com/scripts/prodView.asp?idproduct=4855
Mine burned out at the board connection, looks like crappy solder connections.
Michael
Posted on Aug 18, 2009
DID THIS WORK FOR YOU? MINE APPEARS TO BE A BIT BLACKENED AT THAT SOLDER. MINE SIMPLY WHEN THE LIGHT COMES ON SAYING IT IS GENERATING, IT IS ON FOR 1 or 2 SECONDS THEN GOES OUT.
Posted on Dec 03, 2009
Installed new t-cell and it still says salt level is zero, but the t-cell trips out on high salts,amps. What is the problem?
Depending on the water temperature the actual salt level reading can be inaccurate.
If the water temp is below 65 the reading will sometimes show a lower salt level than the actual level.
Did you recalibrate the power center?
Have you tested the salt level independently?
I would first test the water or have it tested, many pool stores offer this service for free.
It helps to have an accurate reading and not rely on salt test strips.
Once you know the actual salt level you can attemptrecalibrate the system and see what reading you get.
For an aqua rite system you flip the toggle to super chlor, to off and back to auto , wait 5-10 seconds you will hear a click then press the button next to the display , tI'll you see the salt level calibrating.
Oct 25, 2016 | Pool & Spa
What is wrong with my Aqua Rite Electronic chlorine Generator.
when unit goes off see if voltage from transformer if not bad transformer if os bad cell and sensor
Sep 09, 2016 | Hayward-Goldline Aqua-Rite Electronic...
Haywardnet com
bad sensor and clean cell if ok replace both
Jun 01, 2013 | Goldline Salt System Transformer -...
I have a 12,000 gallon abg pool Also the water is from a well system The low salt warning light came on I then cleaned the cell and reinstalled the cell only to have the High salt light come on I then...
any thing over 3500 can create alarms.
First of all make sure you are useing a test kit for salt that reads in #'s not color
your system can read low salt when it is high or even high can read low
The system only really knows something is wrong
your 7800ppm is ridiculously high
Now start draining 20% of your water at a time and refilling giving the system at least 6 hours of just filtering between drainings until you get to as close to 3000ppm as possible
under 2700ppm and you will not produce enough chlorine and can trigger alarms any higher than 3500ppm and you can trigger alarms,go cloudy, and not to mention corode any metal parts like an aluminum ladder
once you get the ppm to 3000 clean your cell one last time and you should be good to go
I would also check your water for metals since you used well water.
you may need to get a metal reducer to add to the pool
Aug 05, 2010 | Intex Automatic Salt Water System for ...
Jun 08, 2009 | Computers & Internet
Computers & Internet Logo
449 people viewed this question
David Payne
David Payne
