Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
How do I remove the top piece to replace the timer. They are made of plastic and I can't get them off feels like they snap into place.
  • 5,911 Answers
If the model number you have this listed under is correct, I believe there is a screw on the back side of the console on each side that you need to remove. With the screws removed, the console will pull towards you (as you are standing in front of the washer) then lift up to access the inside.
If there are no screws in the back, then the console will have a retaining clip under each side. To release, you need to insert a putty knife under the console along the front corner of each side and push straight in while lifting up to release.
If you have questions, or if the model number is different, please post back with the correct information so that I may provide you with better assistance. I hope this helps you.
Posted on Sep 29, 2009
How do you remove the clear plastic cover on the crisper drawer of a Samsung Refrigerator Model RF4287HARS
Yes, the clear plastic front of the crisper drawer can be removed for cleaning. Using a thin-bladed, flat-head screwdriver, pry out at the clear plastic slot at the top outside of the drawer, where the clear front piece meets the tab of the white handle piece. Pry out just enough to get the blade under the slot, and then pry inward at the white tab to release the clear front piece at the top of the drawer. Repeat this procedure on the opposite side, so that the plastic front piece is free at the top of the drawer. Next, turn the drawer over on a counter and work the blade of th screwdriver under the tabs at the bottom of the front plastic piece. These should release easily. Notice the bottom edge has three slots and two sections that are interleaved with the bottom of the drawer. Once you have all three pieces separated, the while u-shaped handle piece, the plastic front panel, and the drawer itself, you can clean and dry them easily. To reassemble, first snap the while handle into place on the drawer, by lining up the top of the drawer to the while handle part first. The top of the handle fits over two plastic extensions on th top of the drawer, then swings down to cover the front sides of the drawer. Then reattach the bottom of the front plastic panel to the bottom of the drawer, interleaving the overlapping parts and snapping the tabs in place. Then snap the top of the front panel over the white handle at the top of the drawer, and you are done!
Dec 04, 2014 | Samsung Refrigerators
Tip
How do replace keyboard on a dell 15 ?
It’s easy to break the flimsy keys on most laptops. Sometimes it’s cheaper to find a laptop keyboardfor your model laptop elsewhere than going through the manufacture. Ifyou find yourself in this situation, you can use these steps to replacethe keyboard. take “Dell Inspiron E1505 Keyboard” for example:
Dell Inspiron E1505 Keyboard US
Removing the Damaged Keyboard…
Enusre the laptop is fully powered off, unplugged from the wall, and the laptop battery taken out.
Turn the laptop over. On some models icons indicating which screwsare attached to the keyboard are displayed. If not, you may have to“eyeball” it if you can’t find a breakdown for your model (such as dell pa 12 or pa 10)online.
Remove those screws with a T-8 or Phillips screwdriver.
Turn the laptop back over and open it up. Check and see if thekeyboard is tucked under any plastic pieces. If so, find if thoseplastic pieces are screwed into anything, and unfasten them as well. Ifnot, it probably uses clamps that can easily be removed.
Remove the plastic pieces carefully with a toothpick or plastic pick if there is any in the way.
Unscrew any screws at the top (if necessary) and remove the keyboarditself from top to bottom. You’ll notice that the keyboard is connectedwith a thin, but wide, data cable to the system board at the bottom.
Take that same pick and lift the plastic connectors that hold in this data cable in place.
carefully remove the data cable. Now the whole keyboard should be free.
Replacing the keyboard.
Take the new laptop replacement keyboardout of the plastic, and slip the data cable back in between the plasticconnectors on the system board. Make sure it’s all the way in.
Use the pick to push the plastic connectors back into place, and make sure it’s holding the data cable in.
Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
Refasten the keyboard in place at the top.
If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
Turn the laptop over and replace all of the keyboard screws.
Finally, put the battery back in and power on the laptop. If all hasgone well, the keyboard should be functioning like brand new.
on Jan 19, 2010 | Computers & Internet
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
How to replace keyboard
1) Take the new keyboard out of the plastic, and slip the data cable back in between the plastic connectors on the system board. Make sure it's all the way in.
  • 2) Use the pick to push the plastic connectors back into place, and make sure it's holding the data cable in.
  • 3) Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
  • 4) Refasten the keyboard in place at the top.
  • 5) If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
  • 6) Turn the laptop over and replace all of the keyboard screws.
  • 7) Finally, put the battery back in and power on the laptop. If all has gone well, the keyboard should be functioning like brand new.
  • Facts about Hardware devices and their invention
  • Oct 06, 2011 | Sharp MM20 Notebook
    Steps to replace keyboard
  • Hi there here's the steps on how to replace a laptop keyboard :)
    2.Use the pick to push the plastic connectors back into place, and make sure it's holding the data cable in.
    3.Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
    4.Refasten the keyboard in place at the top.
    5.If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
    6.Turn the laptop over and replace all of the keyboard screws.
    7.Finally, put the battery back in and power on the laptop. If all has gone well, the keyboard should be functioning like brand new.
  • Sep 29, 2011 | Computers & Internet
    How to remove the keyboard of a HP Mini 110 3130sv
    1. Enusre the laptop is fully powered off, unplugged laptop ac adapter from the wall, and the battery taken out.
    2. Turn the laptop over. On some models icons indicating which screws are attached to the keyboard for HP Mini 110-3130sv displayed. If not, you may have to "eyeball" it if you can't find a breakdown for your model online.
    3. Remove those screws with a T-8 or Phillips screwdriver.
    4. Turn the laptop back over and open it up. Check and see if the HP laptop keyboard is tucked under any plastic pieces. If so, find if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
    5. Remove the plastic pieces carefully with a toothpick or plastic pick if there is any in the way.
    6. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, ribbon cable to the system board at the bottom.
    7. Take that same pick and lift the plastic connectors that hold in this data cable in place.
    8. Carefully remove the data cable. Now the whole HP Mini 110-3130sv replacement keyboard should be free.
    1. Take the new keyboard out of the plastic, and slip the data cable back in between the plastic connectors on the system board. Make sure it's all the way in.
    2. Use the pick to push the plastic connectors back into place, and make sure it's holding the data cable in.
    3. Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
    4. Refasten the keyboard in place at the top.
    5. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
    6. Turn the laptop over and replace all of the keyboard screws.
    7. Finally, put the battery back in and power on the laptop. If all has gone well, the HP Mini 110-3130sv Keyboard should be functioning like brand new.
    Sep 01, 2011 | HEWLETT-PACKARD Mini 110-1031NR Netbook
    Evon610c keyboard keys broken how to replace the keyboard ? how to open the case with out damage internal parts ??
    Hi
    this may help you i found it somewhere online
    How to Replace the hp compaq evo n610c laptop keyboard Removing the Damaged Keyboard
    Enusre the laptop is fully powered off, unplugged from the wall, and the battery taken out.
    Turn the laptop over. On some models icons indicating which screws are attached to the keyboard are displayed. If not, you may have to eyeball it if you can't find a breakdown for your model online.
    Remove those screws with a Phillips screwdriver.
    Turn the laptop back over and open it up. Check and see if the keyboard is tucked under any plastic pieces. If so, find if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
    Carefully remove the data cable. Now the whole keyboard should be free.
    hope this was helpful
    Jun 21, 2011 | Compaq Evo N610C Notebook
    How do I replace keyboard on a asus 1000HD
    HI
    It’s easy to break the flimsy keys on most laptops. Sometimes it’s cheaper to find a keyboard for your model laptop elsewhere than going through the manufacture. If you find yourself in this situation, you can use these steps to replace the keyboard.
    Removing the Damaged Keyboard...
    Turn the laptop over. On some models icons indicating which screws are attached to the keyboard are displayed. If not, you may have to “eyeball” it if you can’t find a breakdown for your model online.
    Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You’ll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
    Take the new keyboard out of the plastic, and slip the data cable back in between the plastic connectors on the system board. Make sure it’s all the way in.
    Thanks for contacting fixya.com
    Dec 03, 2009 | ASUS Eee PC 1000H Laptop
    Samsung ML-2510 printer paper jam
    This happened to me after I had cleared a paper jam. I finally had to take off the back and cover to discover that there was, indeed, a small piece of paper invisible otherwise (torn off of the paper I removed). I removed the piece with tweezers and now it's working fine. Remove all other moveable parts inside. The top front is held on with two plastic posts + screws, the back by four deep-set Phillips screws. Might work best to remove back screws, then front, then top. The top feels fixed, but it snaps out (sounds loud!) with some pressure, and snaps back in on reverse. Harder to replace than take off.. Be sure the light color on the top on either side of the fuser opening slides under the darker color part of the back (about an inch?) before snapping or screwing it all back. Good luck!
    Aug 03, 2008 | Samsung ML-2510 Laser Printer
    The "spinner, 3rd level wash" kept falling off. Ordered new part, no instructions with it.
    I had the same problem, the 3rd level spinner falling off. Without getting into my saga story, save yourself some $$$.
    -You will need a screw & washer to replace the plastic thumbtack. The screw will have to be able to screw into the female part of the spinner; the washer will keep the screw from falling out of the hole in the flat hose on the ceiling of the dishwasher.
    -If you look closely at the spinner(the part that keeps falling off), you will notice it comes apart. With a flat head screwdriver, separate the 2 parts. (there are 3 parts all together; Keep the round center piece sticking out of the top peice)
    --Remove the top drawer of the dishwasher to give you some room to work
    -Remove the screw on the "ceiling" of the dishwasher(it is located further back from where the spinner goes) to allow the flat pastic tube to come down low enough for you to get in behind it.(set that screw aside in a safe place; you will put it back later)
    -Remove the pastic thumbtack from the hole in the flat plastic tube if it is there & replace with a washer and screw.
    -Take the top 2 peices of the spinner, together as assembled & screw the screw into the female portion of the spinner.
    -snap on the 3rd piece of the spinner
    -replace the screw you took out earlier, securing the flat plastic tube.
    -place top drawer
    Voila, you are done!! You just saved yourself $20+
    May 12, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    65 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
