Question about Ruud Heating & Cooling
Hi! The brown wires leading to the blower motor relay are not hot. What voltage should I be reading from the brown wire?
  • 3,361 Answers
The brown wires do not go to a blower relay,they go to a start capacitor. They are power in and power out when the blower is energized through the fan relay.
Posted on Sep 29, 2009
Where is the blower motor relay located. Is it in the blower motor control module?
Are there any hvac trouble codes ? Did you check voltage and ground for front blower motor, with controls turned on? I believe the purple wire is voltage and black wire is ground. If good voltage and ground with no blower action, suspect the blower motor.
With auto hvac didn't see relay, saw blower motor control processor, at control processor, did you check voltage and ground?
As far as replacing the blower motor control processor, that appears to be a very involved procedure. I can't lead you step by step to remove and replace.
Auto.com
Has free repair info, you have to register your vehicle, it is free. Then click on vehicle repair guides, take a look.
If you want wiring diagram, let us know?
Apr 21, 2016 | 2002 Cadillac Deville
Location of heater relay on 2003 ford focus.
There is no relay, according to my info. At the blower motor, green wire is voltage, fuse protected, goes hot with key on. Black wire is ground. The blower speed control switch is part of ground circuit. There are resistors for the lower speeds. Hi speed doesn't use a resistor. If you have good voltage and ground at blower motor and no blower action, suspect the blower motor. Any motor that uses brushes, sometimes you can tap on suspect motor, and it will run intermittently. Sign of bad brushes.
You may be able to use jumper wires to blower motor connector for voltage and ground, from the battery, just to see if blower motor will run? If it won't run, suspect blower motor. If you use jumpers, use an inline fuse, just in case.
Oct 15, 2015 | 2003 Ford Focus
How to wire for 220 v
220 is two hots and one ground. If it were me I would leave red orange and white "together",then verify your voltage on remaining wires. 110, 110, 0. If not, youre no good. Try something different. It doesn't matter what "line" goes to what "load" just as long as one of these goes through whatever relay/switch you are using. Good Luck. Hopefully single phase. If motor runs backwards swap wires.
Mar 14, 2017 | Heating & Cooling
Blower Fan doesn't operate normally
No, it must be the ground for the blower motor, if you have power to the fan. Like this: you ground a voltmeter and find battery voltage on the red wire. Now move the ground lead to the ground wire, positive lead on red wire. If ground is good, meter will register voltage. If no ground, no register of the meter. Double check your ground.
Jan 26, 2013 | Cars & Trucks
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
Blower motor only works on low and medium on 2007 dodge nitro
You replaced the resistor and WHAT relay? The blower motor circuit on a 2007 Dodge Nitro does not use a relay.
The blower resistor gets it's power from the A/C - heater control unit.
If you check for voltage at the blower motor resistor connector (Key on, relay disconnected), the DARK BLUE/GREY wire should be hot when the control switch is on HIGH. The DARK BLUE/VIOLET wire should be hot with the switch in the MEDIUM 2 position.The DARK BLUE/ORANGE wire should be hot with the switch in the MEDIUM 1 position. The DARK BLUE/BROWN wire should be hot with the switch on LOW.
If any of these are not as stated above, then you either have a bad A/C - heater control unit, or faulty wiring between the control unit and the resistor.
Jun 02, 2012 | 2007 Dodge Nitro R/T New Cars
--2005 GMC Envoy AC Trouble--(compressor still active) Have replaced blower motor (original one had "burn" evidence), resistor and resistor connector. The blower is still not working. Have...
SOUND LIKE BAD BLOWER MOTOR RESISTOR.CHECK BLOWER MOTOR HI BLOW FUSE AND RELAY.YOU WILL NEED OWNERS MANUAL IN GLOVE COMPARTMENT TO LOCATED BLOWER MOTOR FUSES AND RELAYS.
Jun 06, 2011 | GMC Envoy Cars & Trucks
Hi I have a 1998 Pontiac Grand Prix and the heater blower motor does not work, if I turn the ignition on and the blower motor is in off position my headlights come on. when I turn the blower motor to the...
This sound like the blower motor relay(lo relay) is wired in to the head light switch voltage.You need to follow the wire from the blower relay (there should be 4 wires) thats hot when the ignition is on and make sure it goes to the blower motor.It sounds like a couple wires got switched.
Nov 17, 2009 | 1998 Pontiac Grand Prix
I have an A.O. Smith f48l47a50 blower motor, and I need help with wiring. First it's a 460v,1phase,1/2hp,975rpm,3spd motor. My question with the wiring is do I need to supply a wire for line power? I know...
are you SURE its 460volt single phase??? that voltage is normally a 3phase motor voltage,and color of wires is right for 480/277, but that would be 3 phase.....not saying your wrong,just make sure
Jul 29, 2009 | Heating & Cooling
Replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Kitchen Appliances - Others
Heating & Cooling Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
