Question about Dell Computers & Internet
I used immation lock in another flash drive optima attache 8 gig. I copied the lock.exe file in the optima drive. I was able to put a password in the optima drive. However, when I restarted, my computer does not recognize the flash drive optima attache 8 gig. When i run my optime flashdrive , suddenlly i had message box ''please insert a disk into drive F: ''. If i want to format the usb flashdisk, the massage box warn me again if computer cannot access my usb. Please help. Otherwise I 8 gig flash drive is lost. Many thanks.
    Scholar:
  • 76 Answers
Hi there !
- you may try this click the start button
-then "right-click" on computer or my computer
-select Manage
-click disk management
-"right-click" on the flash drive, then click format
-cheers!
Posted on Oct 04, 2009
  • Dell Master
  • 32,281 Answers
This progeam may help :-
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Posted on Sep 29, 2009
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
I want to "lock" the flash drive with a password.
    Encrypt Individual Files and Folders on a Flash Drive
  1. Step 1 Choose "Tools" from the menu bar at the top of the program, such as Microsoft Wordmag-glass_10x10.gif, and pick "Options."
  2. Step 2 Select "Security" from the many tabs displayed in the new popup window. Create a password in the "Password to Open" or "Password to Modify" section and click "OK" at the bottom of the box.
  3. Step 3 Confirm your password when prompted. Drag the password protected files to your flash drive. To open a protected file, enter password when prompted. Remember, passwords are case sensitive.
  4. Encrypt Entire Flash Drive
  5. Step 1 Download and install the freeware program "Cryptainer LE" onto your PC or laptop. Enter a meaningful password from 8 to 100 characters and define the file location and size, which you can change at a later time. Enter your password when prompted.
  6. Step 2 Install Cryptainer Mobile when the Cryptainer LE installation is complete. Select "Tools" on the menu bar at the top of your screen. Select "Install Cryptainer Mobile" and follow the prompts. The Mobile version comes with the LE download.
  7. Step 3 Close the LE version on your desktop. Select a location and meaningful password for the Mobile version. To protect important files and folders, drag and drop them into the vault, the location of the encrypted files.
Jun 24, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
4GB Attache flash drive says it's locked.
Plug in the stick. wait for it to come up on the desktop then click on it once. (do not open it).
From the file menu select "Get Info"
In the panel that opens up you will see a row of coloured squares. Underneath is a checkbox marked "Locked"
Is it empty or ticked?
If it's ticked, untick and see what happens in disk utility. If it's not ticked that then would appear to be a problem with the stick.
For what it's worth, I did a google on this stick and found that there are numerous posts about it becoming read only on Vista, so it may well be a problem with the manufacturer.
Sep 07, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Access issue to my flash drive
The drive is probably password protected by Securlock software.
Hope it helps.
Aug 30, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Pny Optima Attache Flash Drive suddenly locked
look for a slider on the flash drive, I had a pny flash drive that had a slider that when enabled would protect the flash drive from accidental erasure or modification of the files.
Jul 27, 2009 | Computers & Internet
Windows says not enough space on pny 8 gig flash drive
Try formatting the drive as NTFS instead of FAT32 (assuming you are using it only on Windows computers). FAT32 doesn't support files over 4GB.
For more info, see http://www.google.com/search?q=fat32+file+size+limit
Feb 08, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
2g attache optima pro black/amber went to write protected...how do I fix it?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Dec 10, 2008 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
My flash drive verbatim 8 gb store and go is not recognized
I looked into similar problems and if this works ill let you knw i downloaded Paragon Pation Manager and i plan to use this to create a 8gb partion on my flash drive i dont know if this will work but ill get back to you
Nov 05, 2008 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
