Question about Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC
Pc installed burner is not recognized by roxio easy cd & dvd creator 6
  • 729 Answers
Hi there
Try to go to Roxio Support here :
https://selfserve.roxio.com/%28S%28heybe055ok2x3k45vykq4045%29%29/Login.aspx
I am sure they can help
IF NOT then return here
Hope that helps
Have a nice day
Please rate my anwer
Posted on Sep 29, 2009
I re-install roxio creator 9, after install windows7, and don't recognize any dvd-cd unit installed, so i can't run roxio creator 9. i have a hp notebook, and roxio creator 9 came with it? what can i do?
Windows7 is still being developed and as far as I know it has some compatibility issue with many hardware etc..Check compatibility with manufacture before you look any further.
Jul 02, 2009 | Roxio Easy Media Creator 9 Suite (227100)...
Lite On LH-20A1H DVD RW burner refuses to recognize DL disks?
I have an LH-20A1S, & I am using Roxio Easy CD
Creator 6; Yes, I know there are newer versions, but they all ****! Anyway, it USED to work just fine in recognizing DL DVD's W/the updates from Roxio's site. & now there is no option there for this size (8.5)w/in the actual Creator prog. Is it the drive? This JUST started happening recently. Any clue if it IS the drive? & if so, any idea what caused this? I've always used Lite-On's & have NEVER had this sort of prob before! & of course it is out of warranty, & a discontinued model to boot! standar DVD drives are real cheap inprice these days, but STILL I do't wanna have to buy an new one if I can 'fix' it. BTW, I have updated the latest firmware for this drive from Lite-On's site too, & it didn't resolve this issue either!
__ERIC
Jan 31, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Error when attempting to write disk
Sometimes the driver that is used to burn CD's gets corrupted, you should try removing and re-installing roxio. The only other possibility is a bad CD burner drive, but these are dirt cheap to replace these days, you should easily be able to find one under 40$.
Jan 20, 2009 | Roxio Easy CD & DVD Creator 6...
EZCD 5.0 and EZCD 6.0
I don't think that 6 and 5 are compatible 6 is an upgrade from 5. I have just 5 on one of my old XP computers and it works fine, but that's all I have. I went to the website and they are not giving any support for Roxio 6 anymore.
I will tell you that Roxio Easy Media Creator is fantastic. The things you can do with that are unbelieveable. I got it at Sam's Club for about $70. But I know that does not solve your problem.
Roxio 5
To burn data files, Open project selector, make a data cd, click data cd project. WhenEasy CD Creator 5 opens and you choose your files to burn, try this: Select Disc at Once Radio button, click okay and click burn.
ID Number: 000008GN Products: General Information
OS: Issue When burning a CD or DVD, you receive an error, burning does not complete, or your media is rejected. Resolution Burning errors can happen for a variety of reasons. Roxio has found that doing the following steps resolves about 80% of all burning issues. Please give all these steps a try and see if it fixes your writing problems.
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. The media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  5. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  6. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Roxio 6
OrangefoodJSLib.events().registerNativeEvent("mousemove",document.getElementById("rating_img"),highlightRating); OrangefoodJSLib.events().registerNativeEvent("mouseout",document.getElementById("rating_img"),ratingExit); OrangefoodJSLib.events().registerNativeEvent("click",document.getElementById("rating_img"),ratingVote); Article Details ID Number: EE6000132 Products: Easy CD Creator 6.x Platinum Suite
OS: Windows 98 Second Edition
Windows ME
Windows 2000 Professional
Windows XP Home Edition
Windows XP Professional Edition
Issue Roxio does not recognize the blank CD/DVD media in the recorder drive.
Resolution Follow the listed procedure to ensure that the CD/DVD media you are using is supported by your CD/DVD Recorder.
On Easy CD and DVD Creator:
  1. Open Creator Classic.
    1. Launch Roxio Easy CD & DVD Creator 6.
    2. Click on the Creator Classic icon.
  2. Check the supported media types.
    1. Click on Tools on the top left hand corner of the window, then select Drive Properties.
    2. Under the Devices section, click on your CD/DVD Recorder drive.
    3. Under Supported Media, click on down arrow to see a list of supported media your CD/DVD Recorder supports.
    4. Ensure that media type that you are using is listed here. If it is not listed then your CD/DVD Recorder does not support that type of media.
On Easy Media Creator:
  1. Launch Disc Information.
    1. Launch Roxio Creator Home menu.
    2. Click on the Tools tab, then select Disc Information.
    1. Under Supported Media, ensure the media type is listed.
    • Reboot.
I do know if you have Roxio5 you cannot installed Nero 6 InCD, not compatible. Other than all of the above, I have no more suggestions. I am really sorry, wish I could work on your computer to figure out the problem. This is my specialty. Reloading computer and figuring out problems. It is so much easier hands on.
Good Luck
Mar 30, 2008 | Roxio Easy CD & DVD Creator 6...
The difference between software
about 30 bucks..actually...the first one is usually for entry level, music only work. creator has the ability to burn data cd's and soon, DVD's with a mixing overlap. Nice product actually.
got backup?
Jan 29, 2008 | Roxio Easy CD & DVD Creator 6...
Roxio
do you have a CD\DVD burner installed hardware?
Sep 15, 2007 | Roxio Easy CD & DVD Creator 6...
Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC Logo
134 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
