Question about Kenmore Dryers
Dryer burns and tears laundry when drying.... Would like to repair myself....looking for a repair manual for model# 41798702891
  • adak12 Sep 29, 2009
    This is getting me much closer to solving the problem...now....can you tell me the best way to get the dryer apart to assess what is causing the tearing and burning of the clothes???
    Thanks so much for the info you have already provided...
  • 51 Answers
If they are almost a brown/rust color marks replaced the front drum seal/bearing part# 5303937139 and 5303283286 here is a picture you will need to replaced # 20 and 23 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=41798702891&productCategoryId=0152000&brandId=0582&modelName=LAUNDRY-CENTER&diagramPageId=00001&componentDescription=BULKHEAD&documentId=P8110065&blt=06
Posted on Sep 29, 2009
Testimonial: "Thanks so much for the info you have provided so far....still need to get the dryer apart!"
  • J. KUYKENDALL
    J. KUYKENDALL Oct 01, 2009
    remove the top of the dryer and then the front panel,control ,door should just fall apart from there
Kenmore stackable laundry center dryer model 417-99570140 - drum seems loose and some clothes have grease or burn marks like they are getting caught. I am not sure how to fix this problem.
repair can be done at home, sounds like either the drum bearings are worn or the rollers are worn/missing/broken allowing the drum to move inappropriately. This is an indepth repair, so if you are not comfortable with it, call in a pro.
Oct 19, 2014 | Washing Machines
Frigidaire Model FEZ831CAS3 insufficient heat?
Without looking at the dryer in person best I can suggest based on years of experience with this particular complaint, is that one of the 2 heating elements is burned out (yes, you can have one burned out while the other still works. If you have no experience in repairing dryers or other large electrical appliances, I would recommend finding appliance repair person locally who may do it for a reasonable cost for you, as usually need to disassemble the dryer to get behind the drum to access the heating elements.
Sep 12, 2014 | Dryers
Kenmore repair manuals
Sears has the best parts and repair website around (even for non-sears items).
Go to the Sears Parts website (link below) and enter the dryer model. It will bring up a visual schematic of everything.
You won't find a repair manual for any specific model - that's something only the service techs get (or understand since it really is technical), but a dryer is pretty simple.
The schematic on the web site will let you see how it goes together and some apart, and as you take it apart you'll simply need to look for parts that look burned or damaged, and take it from there.
Apr 24, 2014 | Dryers
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
My Frigidaire Gallery dryer squeaks and leaves brown crescent burn marks on our laundry items.
If you live in Pasadena, CA and you need a Dryer repair service our professional technicians will perfectly repair your dryer as fast as possible. All you need to do is to call at (626) 460-0903 or visit our website http://www.appliancerepairspasadena.com .
Dryer repair Pasadena CA Bosch LG Electronics Amana Beko
Sep 02, 2017 | Frigidaire Gallery Series GLHS269ZDB 36"...
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 13, 2010 | LG D2526 Gas Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
Jun 17, 2010 | LG DLG7188 Gas Dryer
Not enough heat
You may need to adjust the air flow on your dryer vent.
Problem:
Solution:
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Laundry not getting dry
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Jul 18, 2009 | Dryers
Dryers Logo
106 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
