Question about Audiovox Bosch 718 World Cellular Phone
I have a bosch fridge /freezer ksu 44 and there has been crackling sounds coming out of it and now it seems its freezing in the fridge part as well. There was water on the bottom tray which i cleaned every couple of weeks ,Its only 26 months old. would that be the thermostat that has broken down?
    Sergeant:
    Champion:
  • 232 Answers
Try this first :
turn your thermostat down first until the fridge stops .
turn the thermostat back up only a quater of the way and wait to see if the fridge turns on and off as usual .
if it does , the thermostat is ok .
if it does not , i believe the thermostat is dead .
in regards to the ice in the fridge part , you maybe have the fridge turned to far up but let me know how you go .
Posted on Sep 29, 2009
Fridge leaking
check door gaskets are in good condition Open and close door quickly Wait for maybe 10seconds and try and open the door . If the gaskets are working there will ne a marked resistance to opening
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
Bosch fridge freezer stops working after approx 8 hours. Starts OK and freezes OK but next day it's warming up. Turn it off and back on again and it starts all over again and the problem reoccurs..
Found a solution at
www.reviewcentre.com/vt100228_start50_orderasc.html
Short out the dark blue and the dark brown wires that lead into the temp control dial. Everything now works. This bipasses a dodgy thermister or something. Of course this might not solve all similar problems but it does seem a common fault.
Dec 10, 2009 | Bosch Freezers
Bosch fridge freezer not sure of the settings
The sound is possibly refrigerant moving through the capilliary tubing nothing to worry about.
Mar 03, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Feb 10, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Bosch fridge KSU 44 leaking water from bottom of fridge
Check the hose or the drain hole in the back of the freezer make sure hose is connect and the drain hole is not plugged
Feb 07, 2009 | Bosch KSU49630 Top Freezer Refrigerator
BOSCH FRIDGE
If you have a two door (fridge freezer) some of the newer fridges these days have the cooling come from the freezer to cool the fridge part. Maybe try altering the freezer temp and see if that makes any difference.
Jul 02, 2008 | Refrigerators
Bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Audiovox Bosch 718 World Cellular Phone Logo
309 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
