Question about Envision EN-7220 17" Flat Panel LCD Monitor
I posted a problem in which my monitor was cycling on and off. I have been told that it is apparently caused by blown capacitors, probably in the power/inverter board. But how do I get in to try to fix it? I have removed the visible screws and the screen bezel, but the screen is still firmly attached to the rear of the case. What to do?
  • davagain Sep 29, 2009
    everyone seems to agree that the most likely culprit is a blown capacitor on the power board. Also, the consensus is that it is not worth fixing. Therefore, I felt that I had nothing to lose by tearing it down. Worst case - its junk. Best case - it works. Anyway, I finally got the screen out of the rear case - it was just held in with catches. I checked the power board and found a visibly bulging capacitor. I know there could be another bad one that looks fine, but I'm going to start by replacing that one. Getting access to a single capacitor at a reasonable price has turned out to be a challenge, but I think I have it worked out. I did check the service manual and the layout appears to be pretty logical. I will probably not end up with any leftover parts (famous last words, right up there with General Custer's "they look friendly") Well, we'll see what happens when the capacitor arrives...
  • davagain Jan 20, 2010
    UPDATE: The capacitor arrived, I de-soldered the old capacitor, replaced it with the new capacitor and viola - works like new! (and no left over parts). The 2 biggest challenges in the whole project: (1) prying open all those latches without damaging anything and (2) finding the replacement capacitor at a reasonable price. All in all, not an unpleasant process.
    Novelist:
  • 152 Answers
Davagain, Just now saw your new post above. If you are intent on delving inside your unit, let me caution you to be very careful in doing the disassembly. Above all else, you must take care to not do more harm than good!! That said, you should try to find and view some video clips on youtube that will demonstrate LCD monitor tear-down. The ones that are >8 -12 min run time should be of help in your quest to "PART" the rear cover from the front BEZEL which holds the LCD panel. Right now you are at the most difficult and dangerous STEP!!! Use extreme caution in any further disassembly procedures. There should be no need to remove panel from the bezel. If digital camera is availiable use it to do your DOCUMENTATION of how things came apart so you can reassemble without having "LEFTOVER" parts. Good luck guy. Do you have a large magnifiying glass to inspect soldering of the printed circuit boards? get back to me with results of inspection. louie12fix or lmistyrel @aol.com Bye for now.
Posted on Sep 29, 2009
See my response to the questioner "rlwalker393" just above yours.
Posted on Jan 17, 2010
HPS6373x/XAA Power issue
Needless to say, it's probably not a blown capacitor. If the unit will not power on at all (control/standby indicators are not lit) the problem may be as simple as a blown fuse on your SMPS (near the AC socket) or on your Main Logic PCB. You should also use your fluke/voltmeter to verify that the Vs, Va, Vsc, and Ve values are reasonably close to those specified on the panel label. Re-post your findings!
Dec 16, 2013 | Samsung HP-S6373 63 in. Plasma Television
Screen lights up then goes out i think its a bad capacitors but i cannot find any capacitor thats looks like its blown or out
Bad caps can look normal but can have high ESR (Equivalent Series Resistance), also it can be lamps problem. You need to read my troubleshooting guide to help you narrow down the cause.
Post the pictures of the caps of the board will help also.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 05, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My monitor slowly got dimmer until it went completely black.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Sep 26, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Computer wont boot Evo d510
Choose within this options with regards to your monitor: 1. You could replace your monitor with a new one. 2. Or you could send someone or send it to a technician to repair your monitor.
Boot Up Problem: 1. Try checking the Power Supply Unit (PSU) if it give out 12Voltz. If not you could replace it with new PSU. 2. Check the motherboard if there are some blown out Capacitors. If there is, send it to a technician to replace it. If none, replace your Processor. That is the defective. That causes the boot up problem.
On boot up screen. Of course it will not show a boot up screen because there is a problem on your monitor. And so, there is also a problem on your motherboard (Processor or Capacitor).
Hope this might help. Thanks.
Jul 12, 2010 | Compaq Evo D510 Minitower (Open Box)...
Blinking Monitor
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 06, 2010 | Princeton Digital VL1918 Monitor
Monitor cycles like circuit breaker cycling.
Check the caps in the power supply with leaking/bulging top.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 01, 2010 | Princeton Digital VL1916 19" LCD Monitor
The screen goes dark. When U cycle the power switch off then on again the screen display returns for about 1 second then goes dark again. I would appreciate suggestions on what to do.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 21, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Dead monitor dell e173fp lcd monitor
This could be either down to an internal fuse blown or the main board or the capacitor on the power supply could be faulty.
jonno
Sep 04, 2008 | Dell E173FP 17" LCD Monitor
Screen Blackness (NOT like all the other ones)
Not all inverter problems will be visually apparent. Some capacitors fail with a high ESR and the only way to check that is with an ESR meter. Output transformers can fail subtly and you may have to test them with an ESR or low-ohms meter, but even that may not be definitive. Parts can be shorted or open without showing burns. It could also be a bad lamp / bulb.
Jan 21, 2007 | LG L1951S (Black) 19 in. Flat Panel LCD...
Envision EN-7220 17" Flat Panel LCD Monitor Logo
271 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
castletech
castletech
Jim Goldsmith
Jim Goldsmith
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
