Question about Bosch Dishwashers
Bosch SHU5302UC/U11 dishwasher does not start, timer window shows 13 minutes at power up but does not run. How to reset?
textonor
  • 130 Answers
SOURCE: Bosch dishwasher SHU66C02UC
You have water in the base of the machine. There is a flood float in the bottom so if any water gets into the base, it will shut off the water and run the drain pump as long as the power button is on. So shut off the breaker, remove the toe kick, and remove any water that is down there. Now start the machine and see if water is leaking into the base. If there isn't any water, an the dw is still running the drain pump, then with a wooden spoon raise the red plastice stick on the left side of the dishwasher up and down. It is possible that the overfil float is stuck. If this makes the dw start filling, then run cooking oil thru the dishwasher on the scrub cycle to remove excessive detergent. If you are in hard water, then the water deposits have caused this. Run citric acid ( Tang orange drink, Dishwasher Magic, or such) thru the dishwasher to remove this.
Posted on Feb 02, 2008
SOURCE: My Bosch dishwasher won't shut off. The timer says
Bosch SHE44C06UC
The dishwasher continues to run...I followed instructions and performed the diagnostic...the light above the quick wash was solid, the light above the rinse/hold was flashing...the code displayed in the cycle countdown window was P0...now assuming the machins isn't "pissed-off"..can you help-
Posted on May 03, 2009
Macmarkus
  • 2605 Answers
SOURCE: I Have a Bosch SHU5312/u11 that is showing 2H on
To answer your first question, in a word Yes. To address the second question, Yes. The control module is easy to replace but the better news is it is also repairable, ( you can make an educated decision when I'm through on whether to replace or repair, that is obviously up to you ) but I'd like to enlighten you if you'll allow on what to look for, and why.
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless pressing the two buttons for "cancel". It has nothing to do with a "delay". The 2H stands for two hours and is actually the estimated time the unit took to complete it's previous cycle based on data to the control gathered and stored in memory...it is not "actual" time, it never is on Bosch. there are far too many variables to be "actual" time and since it only goes to two hours in the display, that's what is displayed even if it runs for four hours.
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at 2H ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
macmarkus :)
Posted on May 01, 2010
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
Macmarkus
  • 2605 Answers
SOURCE: How do I run Test mode for a Bosch SHU5302UC
Hello, welcome to FixYa.
I`ve attached a document which should answer both of your questions, if it worked.
Let me know if you have any problem reading it or require further assistance.( you may have to copy and paste it in a "windows viewer program" or the like to enhance it, I couldn`t with the limited resourse I have at the moment ).
I could email it to you if you want to post an email...if this doesn`t work.
Thank you for visiting FixYa to day. Please take a moment to rate the assistance I provided for you here today.
Good luck.
macmarkus :)
Posted on Jul 13, 2010
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
My bosch dishwasher control panel displays 0H on the time delay. When I start it the OH go to 2H. It then starts running and does not stop. The cycle minutes don't display. It's model number SHU5302UC...
check to see if your unit has a recall on it because if it does you will get a free control module from bosch.
your problem is the control module. thermador .com is the site to lookup. gaggenau,bosch,thermador they are the same ccompany. let me know if this helps by sending a 4 thumbs up post
Feb 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
SHU5302UC dishwasher will not spray or pump.
Pump motor would be where I would start. It could be something that has the impellers locked up so they wont turn or the motor could be bad
Jan 28, 2010 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Bosch SHU5302UC/U06 dishwasher starts at 2H and eventually starts but continues for a long time at 1 without rinsing the dishes.
I had the same problem a few years ago and the tech replaced the control panel. No problems until....last night. Now a different problem.
Jun 17, 2008 | Bosch Dishwashers
Endless cycle with wet dishes
If it's a Bosch, check for Rinse Agent (e.g. JetDry). Rinse agent is not optional with a Bosch.
Apr 14, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch shu5302uc - overfill pump wont quit running
Have you tried to shut down the breaker for the unit and turn it back on ??
Feb 07, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Dishwashers Logo
87 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
