Question about Lexmark 2381-003 Dot Matrix Printer -28845
How can i test print my lexmark 2381-003 dot matrix.not using windows?
3 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: fix page printing
Not Familiar with this printer particularly But if you reduce 'paper' size presumably the printer will reduce the image to fit. Did you try that?
Posted on Aug 27, 2007
Ajkill
  • 2035 Answers
SOURCE: Lexmark 4227 Plus Matrix Printer on Vista
Operating System Printer Driver Installation Procedure
NOTE: This procedure involves driver installation and port creation using Microsoft's Standard TCP/IP printing.
Step Action Click on Image 1 Click on the Microsoft logo start button. pattlnk_3212007_1551-vistastrtsm.jpg 2 Click on Control Panel. Image 3 Click on Hardware and Sound. NOTE: Classic Mode users can double-click directly on the printer icon. Image
4 Select Add a printer.
Click for Image 5 Network installation
Select Add a network, wireless or Bluetooth printer (for direct IP printing, network print queues - \computernameprintername, etc.)
NOTE: For printers connected via LPT1 (parallel), select Add a Local printer (e.g. IEEE- 1284 compliant printer cable, etc.)
Image 6 Observe Searching for available printers...
Upon completion, select (highlight) your printer, and click Next.
Your printer's IP address will be displayed under the printer description. Use the IP address obtained under Recommended above.
Available Windows Vista Search options:
  • Stop Search - Select this if you can identify your printer prior to search completion.
  • Search Again - If your printer does not appear,determine whether the printer is on the same segment of the networkand confirm successful communication with the printer.
HINT: Windows Vistawill only search the local subnet. If you are confident that theprinter is communicating over the network, select The printer that I want is not listed and try to add the printer's IP address manually.
Image 7 Observe Detecting the TCP/IP Port...
NOTE: Windows will automatically move to the next page when the detection is finished.
Image 8 Observe Detecting the driver model...
NOTE:
Image 9 The Printer name will appear, click Next.
Optional: If youwould like a distinctive printer name and do not want this printer tobe your default (i.e. main) printer, enter a different printer name and deselect Set as the default printer. Image 10 Observe Installing printer... Image 11 Upon completion, a Windows test page will print. You can verify the printer's installation by opening the printer's window.
Posted on Feb 23, 2009
How to give test print through command prompt in windows-10.
you can print a test page from the command prompt using this command:
rundll32 printui.dll,PrintUIEntry /k /n “\\atl-ps-01\color-printer”
If you wanted to, you could wrap this command up in a VBScript and execute the test page from there. For more information about running command line tools from within a script take a gander at this classic Tales from the Script column (it’s actually the first Tales ever written
Jul 01, 2016 | Matrix Office Equipment & Supplies
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
Skips pages while printing
check the page length set on printer/ system/print server in printer & fax
Jul 26, 2013 | Lexmark Forms Printer 2590 Dot Matrix -...
How to print pdf document in lipi 6306 printer
It depends on what you mean by printing a PDF.
You can not "Direct Print" PDF documents on the 6306, you will need to pass the document through an appropriate printer driver / filter depending on the operating system used.
Simply sending a PDF document to the printer will not work
If you are using Windows simply print the PDF from Adobe Acrobat using the appropriate Windows Printer driver. If you can print a Windows Test Page, you should be able to print a PDF document- The quality of the print may not be of laser printer standard- Remember this is a Line Dot Matrix printer
Apr 03, 2013 | Tally 6312 Matrix Printer
Want to print draft mode in dot matrix printer in XP
Not all dot matrix printers will print in draft mode. When operating from DOS it was usually necessary to send an Esc(ape) code such as ESC @ in ASCII code. I don't think it can be done from Windows; in fact some windows programs will not even talk to a dot matrix printer. Some printers have one or two banks of DIP switches, but before changing them you need to read the manual to see what they do. There could be one which allows Draft MOde.
Sep 24, 2009 | Epson LQ-1050 Matrix Printer
Difference between dot matrix printer and laser printer
1. Dot matrix as the name suggests prints in small dots. The print out u get in railway tickets. 2. Laser printers are very speedy and have clear and sharp printing. There is no comparison b/w a laser printer and dot matrix. If dot matrix is 1st GEnaration than laser is atleast 10 generations ahead
Aug 20, 2009 | Absolute Software ComputraceComplete for...
I have poor print quality on my Lexmark 4550
That obviously shouldn't happen. Did you print an alignment page after you inserted the new cartridges? There could also be some clogged nozzles on the new cartridges. If you haven't contacted Lexmark technical support through www.lexmark.com, suggest you do so.
Aug 05, 2009 | Lexmark X4550 Multifunction Wireless Color...
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
NOTE:
Feb 23, 2009 | Lexmark 4227 Matrix Printer
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
