Question about Panasonic PT-51HX41 51" Rear Projection Television
Tv is zooming in and out
My panasonic tv is zooming in and out. when it zooms in the outside of the screen middle warps in making the picture look like this ) (.
  • benitto Dec 25, 2007
    My Panasonic 28-TX PL10 has exactly the same problem. I thought it was something I could fix using the remote but it will not go away. Help would be appreciated.
    Den
  • 87 Answers
Sounds like you need convergence IC's. Don't let them use GENERICS/KNOCK OFF'S!!!
Posted on Dec 20, 2007
My panasonic dvd player will not show the whole screen when in dvd mode
Hi
First make sure your Panasonic has 16:9 TV mode selected within its menu. Then try chainging the picture size on your TV. You didn't say what model TV you have. On my Samsung you would press the menu key then select picture, scroll down and select picture size. From hear you can select 16:9, wide zoom, zoom, 4:3. Try looking for picture size and selecting 16:9 on your TV.
Jun 03, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
My tv screen is too wide horizontally. I can't see but what's in the middle of the picture. Do I need to purchase a new tv or is this something that can be fixed?
go into video set up and take tv out of zoom mode
it sounds like you have it set to zoom a standard definition signal and that will make picture become bigger than the screen and cut picture off
hope that helps
Mar 25, 2011 | Polaroid TTM-2401 TV
It appears that the image on the screen is zoomed in, but I can't figure out how to "undo" that. Thank you!
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
Oct 16, 2010 | Panasonic CT-27SL14 27" TV
HD TV screen is zoomed to far out. How do
Use the Picture, Zoom, or Aspect button on the TV remote to cycle through the available screen sizes. You may also be able to set screen size in a Setup-Picture (or Video) menu.
Jan 18, 2010 | Televison & Video
Picture zoomed in and now not all picture is showing
Did you try to zoom out?
When you zoom in, your TV removes some portion from the edges of the picture and shows the rest full-screen.
If you want zooming out instructions, please provide information about your TV's make and model.
Thank you.
Nov 04, 2009 | Televison & Video
Picture is too big for screen
You will have a button on the _original_ remote that says Format, Aspect Ratio, Zoom, Size or just AR. It will cycle through Normal, Stretch, Partial Zoom, Zoom, Gray Bar, or the like. You are not in Normal but in one of the Zooms. Stretch is used to make 4x3 movies fill a 16x9 screen, may not be desirable. Zoom is used to fill the 16x9 screen with movies that have been letter boxed. Gray Bar fills the sides of a 4x3 picture on a 16x9 set with gray to "avoid" burn in. Use normal except zoom on LB. -Ken
Oct 04, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Panasonic plasma
go in to your tv's menu and go in to picture settings , you either have the zoom function on or its been set on 4:3. check these and if zooms on turn it off or if 4:3 is on switch to 16:9
Nov 28, 2007 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Panasonic PT-53WX53G screen got larger, corners are warped
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Nov 13, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic TV 50 inch plasma
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Nov 08, 2007 | Panasonic TH-50PX75U Plasma HDTV
Panasonic PT-51HX41 51" Rear Projection Television Logo
170 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
