Question about Alpine MRD-M301 Car Audio Amplifier
Amp turns on no output power wont power subs
Always turns on digital screen lights up menu works, no output power
SOURCE: powers up but no signal
Check your gain pots as well as audio pre outs on amp. sometimes pre outs will get loose and be unable to make a connection.
Posted on Jun 30, 2007
  • 13 Answers
SOURCE: Kenwood KAC-749S
Try to take out the lights that you put in yourself, but do it carefully, as you might have bridged out the power connectors that go through to your subs.
Posted on Aug 15, 2007
colin324
  • 57 Answers
SOURCE: Lights on, nobody home
Appears to be an issue with current. Is the speaker the correct impedance for the amplifier ? Have you confirmed there are no short circuits in the wiring ? I'm not familiar with this particular product,
The alpine catalogue gives recommended amp/speaker combos. If you don't have an aplpine sub, then look at the specs and find a similar one. You may be trying to load the amp too heavily and it will protect itself.
Posted on Nov 21, 2007
  • 631 Answers
SOURCE: 250/1 powers on but no output
If the amp is not going into protect, the power supply FETs have probably failed. In the corner of the amp near the toriodal transformer, there are 4 FETs against the heatsink. When these fail, the 47 ohm resistors at the base of the transistors often fail. If the resistors are dark, it generally means the FETs have failed. If you disconnect the amp from power and measure the resistance from leg 1 to leg 2 of the power supply FETs, a reading of near 0 ohms indicates the FETs have failed.
Posted on Dec 31, 2007
SOURCE: no output
Maybe you should check your remote wire!
Posted on Jun 05, 2008
Preout section cannot ingage
If you are using a pre out to a sub woofer, you need to make sure that the sub has it's own power amp or it will not work. You also need to go into the user menu and tell the amp that you are using a powered sub. Otherwise it will not turn on the pre amp output
Jun 20, 2012 | Denon Avr1610 5.1-channel Home Theater...
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
Basicly my speakers were working fine, my subs were working fine but everytime i was turning my volume up to a certain level i would lose all base and all noise from the subs in my boot, so i turned it...
The amp should always light up showing you that it is powered and there will also be a red light that will light up if theres something wrong.Sounds like maybe the hot wire that goes to the amp isnt big enough to give the amp enough power.Check your positive wire and ground wire for tightness and make sure hot wire supply is big enough and also the ground wire is big enough and has a good ground.I hope this Helps you.Have A great day..
Mar 31, 2009 | Pioneer GM-X722 Car Audio Amplifier
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
SUBS NOT PLAYING THROUGH AMP
There is an otion to turn sub output on/off in the "audio menu". Hit " in lower left to turn sub out put on.
Mar 17, 2009 | Xtreme Sound WMS336 CD Player
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
RED Port light on AMP?
are you sure its not PROT?
the amplifier is protecting itself from fire because of something.
Disconnect the subs. and turn on.
if it comes on normally, the subs are at fault and will need attention. If the light still stays on, you hafe probably blown an output on the amplifier and it will need repair.
Dec 24, 2008 | Sony XM-2200GTX Car Audio Amplifier
Da2200w wont kick out sound....
try using another input device for sound like a differert stereo or an ipod or try using another input channel on the amp such as high level or low level please rate -jeff
Aug 31, 2008 | Digital Audio 2, CHANNEL 600 WATTS HIGH...
No output
Apr 16, 2008 | Hifonics Brutus BX 1605D Car Audio...
Blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Mar 17, 2008 | Alpine MRV-T757 Car Audio Amplifier
Alpine MRD-M301 Car Audio Amplifier Logo
51 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
