Question about Accutek Dryers
Accutek wall fan model#ARW-4204/ARW4604 power init but not getting any ting from the brain which goes to show that it is not spining what could cause the problem, it has gotten lubrication and still not spinning.
3 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: Accutek AOJ 1601R fan wouldn't start
hi there,
it always can fix,there are several factror to check,you should have a multi tester to use to check the circuit.it might be on the switch,
cable or on the motor.
open the control box of the fan,there are set screw loosen this and you will see the connection of electrical connection of cable supply and the swicth.
set tester on rx1 check continuity of the cable plug supply,red rod of tester on plug take one wire,black test rod on the other end of cable plug.this other end of wire is on control box.see if pointer of tester move on to no.10 or 20ohms if move its good.try also on the other side of wire.if does not move replaced the wire.
if you can see a fuse check this,by tester
on rx1 attached red test rod on one end of fuse black rod on the other end,if move the pointer its good but if not,replace fuse,actually all fan motor have thermistor fuse inside the motor,it was mounted on the inner side of winding of
motor it look like a resistor or sometime a form of small square resistor has two terminals,to test this, red test rod on one terminal and black test rod on the other terminal if pointer of tester does not move replace thermistor.
to get the termistor fuse you should open
the motor,this is not easy job.but small pc. of motor will give you knowledge how to fix your small appliances.,on motor there are four lock in bolt,before you can pull out the motor disconnect the wiring from the switch cut this
by cutter plier leave a small color lead of wire
when you cut,allow you to remember the connection when putting back.when you dismantle the motor,loosen the four lock in bolt and pull out the winding on motor case
on winding cut the plastic strip,find the thermistor fuse,this was insulated,careful to cut small wire this are all terminal of motor
replace the thermistor if busted.
put back and try to run your fan again.
unplug your fan before doing this this should be done by technician,have anice day rate my fix thanks a lot.
Posted on Jun 13, 2009
MNfisherman
  • 11896 Answers
SOURCE: phantom ceiling fan power
the switch will need to be replaced.
Posted on Sep 16, 2009
We just recently installed a harbor breeze ceiling fan w/light and remote. During a storm the lights just quit working. What can we do?
Power outages cause ceiling fans to suffer memory loss. The basic "cure" is to disconnect fan power at the source and, while waiting a few minutes, remove the remote battery and press all buttons to verify that none are stuck. Reinstall the battery and test operation. Other factors may affect restored operation such as using wall switches and pulling the chains. The simple brain in the fan canopy can't remember switch and/or pull chain settings at the instant of power loss.
Jul 24, 2016 | Dryers
My Accutek not blowing out the air from the fan what is wrong with my fan
There is an 'enter' side and a 'blower' side to each fan. Is it spinning the proper way?
Jul 02, 2015 | Accutek AOJ-1601 Stand (Pedestal) Fan
Where can I get new blades for my accutek oval oscillating fan
Enter the model number of the fan into a search online. You will find various websites with a parts break out view. Each part should have a model number, and a price. Try contacting the manufacturer if you need more help.
Oct 22, 2014 | Dryers
Agent in Malta for accutek fans
www.accutek.com.tw/
Consider asking the company if they have an agent there.
Oct 20, 2014 | Dryers
I have an Accutek fan that is not working. Where can I have it fixed in Cape Town? I would like someone to look at it to see if it can be repaired before I incurr costs?
I also have the same problem with my Accutek fan. I think it is the bearing that is going as it is making a noise .It is like running and then jamming as something is restricting it. I also live in Cape Town and looking for someone to fix it.
Jan 24, 2014 | Accutek Dryers
I have a A0X-1202 Accutek fan, it wouldn't start. It worked fine before but today it just won't start. Can it be fixed? What possibly could be the problem?
1st, remove the poer cord from your fan and determine if you have any breaks in the line by checking the voltage ( 120 volts) coming from the bare wires when it's plugged in. If nothing registers on your volt-multimeter, you can easily repair the cord or just replace it. Check to see if that works, and if not, ask me the next step.
Sep 21, 2012 | Accutek AOJ-1601 Stand (Pedestal) Fan
The wash stop spining
Their is no belt or transmission. The brain might have detected an anomoly of some sort such as: slow drain, this is the most popular sometimes objects get into the small electric pump causing it to take much longer than usual to empty the water. The brain shuts down the machine for fear of a overflowing drain etc. The load could be unbalanced or too many in there for the motor to spin top speed and that can cause the brain to shut it down. At any rate you should get some sort of fault code. I have a Cabrio manual HERE
Jan 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Accutek aoj-1601 stand fan problem
An electric motor shop may be able to rebuild the motor for you, or you may be able to find a motor with the same ratings. Chances are this would be pricier than a new fan though.
Jun 23, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Accutek stand fan just hums, won't turn
That means the bearings are dry and have locked. Simply open the motor cover by removing the screw and pull the oscillation knob by rocking it side by side gently to have free access to the motor.
MAKE SURE THE FAN IS UNPLUG FIRST. Use cream type grease on both ends of the shaft. After applying the grease rotate the blades until they're freely and you feel the blades have released.
Place the motor cover back and the oscillation knob and plug-in the fan. Leave it on HIGH for 10-minutes or more to make the rotor loose with the grease.
Jun 15, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Dryers Logo
67 people viewed this question
Top Accutek Dryers Experts
ray gallant
 Russ Hill
Russ Hill
Are you an Accutek Dryer Expert? Answer questions, earn points and help others
