Question about Microwave Ovens
The microwave has no power and i have unplugged and plugged back in still no power. Is there a reset switch?
    Brigadier General:
  • 4,090 Answers
No but there is a fuse under the exterior cover, usually on top left hand side.Usually thi is a ceramic heavy duty fuse of around 30Amps.
Please rate our help++++Thanks for using FIXYA
Posted on Sep 29, 2009
After a power surge, the display comes on. Yet, the buttons do not work. Is there a button to reset?
Is this a one time event? Try unplugging the unit from the wall for at least one hour and plugging it back in. Open the door and close it. I'm not familiar with this particular model but I have to guess that you push the stop/reset button to set the clock after plugging it in. It may be a bad touch pad or a bad door sensing switch.
Sep 19, 2013 | Danby Designer Series DMW077BLSDD 0.7 cu....
Microwave won't turn off
Well first of all switch off your microwave oven from main plug and unplug the power cable from power switch. After 30 min. put the cable back to power plug and check you microwave again. If further you have the same issue then post the brand and the model number of your microwave for further assistance.
Good Luck
Nov 06, 2011 | Microwave Ovens
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
My microwave want cook
Hello
and/or circuit breakers, particularly in the case of recent power failure, and reset if necessary.
Unplug the microwave, wait 30 seconds and plug back in to the power supply to reset the microcomputer.
Open and close the microwave door firmly and press "Stop/Reset." Select a new cook time and press "Start."
Ensure a proper cooking temperature and/or time is chosen, as low cooking temperatures or short cooking times may prevent the microwave from heating food appropriately. Press "Power Level" to ensure the microwave is cooking at 100 percent power.
Contact an authorized service technician if the problem is still unresolved.
Oct 04, 2011 | Sanyo Microwave Microwave Oven
The switch button is not working..
Hi, kindly unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the problem continues, the touch pad should be replaced asap.
Mar 27, 2011 | Amana RFS18MPS Microwave Oven
Won't work
unplug your microwave; remove the top under the top you will see a small white cylinder
(a ceramic fuse) it looks like a glass fuse only made of white glass replace this they are sold at radio Shack
Apr 22, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
MICROWAVE NOT WORKING PROPERLY
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Otherwise, it sounds like a bad door switch or door switch mount.
Aug 20, 2008 | Daewoo Microwave Ovens
Microwave F-7 Code
F7 is q Power to magnetron
interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check resistance of the magnetron thermostat.
6. Check the magnetron.
7. Check P2, P4 and P27 connections.
8. Check wiring to the 1100W inverters and control system. See
“Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace inverter, if defective.
11. Replace all parts and panels before operating.
12. Plug in microwave oven or reconnect power.
13. If problem persists, unplug microwave oven or disconnect power.
14. Replace electronic control.
15. Replace all parts and panels before operating.
16. Plug in microwave oven or reconnect power.
17. If problem persists, unplug microwave oven or disconnect power.
18. Check for reversed plug connection on controls or loose wiring.
19. Replace all parts and panels before operating.
20. Plug in microwave oven or reconnect power.
Aug 08, 2008 | Whirlpool GH6177XP Microwave Oven
PANASONIC NN A 770SBBPQ
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Apr 22, 2008 | Microwave Ovens
MICROWAVE DOES NOT SWITCH ON
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
