Question about Konica Minolta Office Equipment & Supplies
Affter adding developer to my konica 2223, How do I reset the machine. (to clear ''routine service req'' on the display.
  • Konica Minolta Expert
  • 158 Answers
Turn the machine off hold down 4 and 7 key turn on enter 9 0 then the date power off then on while holding 47 again and press 5 1 and start if you dont run the 5 1 you will get an error code and not be able to use the machine
Posted on Oct 03, 2009
Testimonial: "Dear sir, The solution gave to me is worked very well. Thank you so much. "
After adding yellow developer in bizhub c360, the machine immediately start to give an error code of c2556 what is the problem and how to fix this... I real need your answer(shekinah.il1992@gmail.).
by adding manual developer, value changed, so try to reset many times and meanwhile add toner from service mode.
else need to change developing sensor chip
Apr 01, 2017 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 195 shows M2 error after changing the developer how to reset M2 error?
Did you also replace the drum, clear the developer counter first before installing the developer, and run the required F 8 procedure after the developer was installed, As the machine uses the counter to control voltages to certain assemblies, not replacing the parts and resetting the counter will cause codes and image issues.
Jan 19, 2016 | Konica Minolta bizhub Office Equipment &...
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Konica Minolta bizhub 210 error m2 appear on display
Hi
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Press ADJUST
Press CLEAR DATA
Turn OFF Copier and Switch it ON
Feb 28, 2010 | Konica Minolta Office Equipment & Supplies
How do i set up a konica 2223 copier to print using it as a network printer
the 2223 does not have that feature if you want a copier that is comparable to the same speed and features you would have to buy the konica minolta bizhub 222 new model or there are a lot of low mileage used bizhub 200 machines coming off lease for sale
Sep 28, 2009 | Konica Minolta Office Equipment & Supplies
Error code P27
Description
P26 or P27 at power up or during copier operation.
Solution
PROBABLE CAUSES:
1. Open connection from the TDS sensor to the main CB or lack of developer. The TDS output is abnormal (0.2V DC or lower).
Verify that the sensor output is above 0.2V DC by monitoring CN6-A9 on the main CB while running the main motor in diagnostics (47 mode, output code 40).
Repair any poor connections to the TDS sensor and supply developer if necessary.
2. Code occurs after resetting the PM counter and P26 occurs if machine is powered OFF/ON, because the L-detect (TDS) adjustment was not performed
Jun 01, 2009 | Konica Minolta Office Equipment & Supplies
Displaying mualfunction detected (bizhub 250)
i will like to know how to reset the page count and service my konica myself, also my konica bizhub 250 is showing C-0204
Feb 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Frequent paper jams with my Konica 2223 photocopier
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
Konica 2223 Developer Calibration
hello sir;The procedure for developer replacement as follow;
1, power off, press 4&7 while turn on the power.
2, enter 51 then hit start
3, press "stop/clear" key to end of out put.
4, turn power off and back on.
Feb 05, 2009 | Ricoh Aficio 450 Copier
Konica 7020 copier
what happens when u run L-detect. Make sure the sensor near the drum sep claws in the drum unit is clean. Any toner or setting powder on this semsor will give u errors while running L-detect.
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
152 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
