Question about Hayward 1.5 Hp Northstar High Performance Pump
My hayward northstar pump makes a loud noise when
My hayward northstar pump 1hp makes a loud noise when it runs. it does pump water, what should I look for to replace?
  • 990 Answers
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Posted on Oct 03, 2009
I have a Hayward Super Pool pump for my inground pool. Was running the pump, heard a noise, by the time I got over to the pump to check it it shut off. It has been off for over 2 hours. It is not hot....
Get another brand. Hayward is junk. I had the same exact thing happen. Of course warranty is only one year. I paid out of pocket to replace the motor. Guess what happened 2 years later?
May 08, 2014 | Hayward Pool Products Hayward Northstar...
Pump runs for about 3min and shuts off
It sounds like it is overheating. There is a thermal switch that shuts the motor off if it gets too hot. This may be because the motor is pulling too many amps due to a bad winding or the bearings are starting to seize. The best solution is to replace the motor.
Jan 11, 2013 | Hayward Pool Products Hayward Northstar...
Pump runs for about 3min and shuts off/
That's the motors internal thermal switch doing its job. For some reason your motor is running hot. With the breaker off, remove the end cap on the back of the motor and use a 9/16 open ended wrench to see if the motor shaft turns freely. If it doesn't there may be some debris jammed at the impeller, or the bearings may be failing.
If the shaft moves freely the problem is probably internal to the motor. Usually a bad winding, Northstar pump motors average about 4-5 years, so if it is older than that or getting close the best bet is replacement.
Can't get my Hayward Northstar SmartMax pump to pull water, it only makes a noise and does not pump water
Have you looked at the vanes in the impeller? if they are significantly clogged nothing will pump or flow.
Oct 24, 2012 | Hayward 1.5 Hp Northstar High Performance...
I have a NorthStar pump. The motor went out so I have it replaced with a different manufactured motor (WEG). Same HP and even a higher SF factor than the original. The new motor draws 10 amps (rated is...
THATS WHAT YA GOT 2 DO ..SOUNDS LIKE YOU HAVE THE WRONG MOTOR .9.6amps IS A 1 1/2 HP ... A 1HP IS 7.6amps.. SO A QUICK FIX WOULD TO GET A 3/4 HP IMPELLER , THAT WILL GET YOU BACK IN THE NEEDED HP RANGE .. welcome to the HAYWARD NORTHSTAR .. HEY IF'N I WAS ANY HELP COMMENT OR VOTE ..JAY
Aug 19, 2010 | Hayward 1.5 Hp Northstar High Performance...
Northstar 1.5 hp pump motor is always hot and shuts off for ten minutes aned comes back on. The voltage and amperage is good. What's the problem
It has an internal thermal overload protection device that is turning it off. Once it cools enough it will automatically turn back on as long as whatever switch or timer you have controlling the pump is in the on position. If you are certain it is not due to a voltage or load condition then it would seem the only other problem is mechanical.
In any case try a local electric motor repair shop.
Aug 08, 2009 | Hayward 1.5 Hp Northstar High Performance...
Noisy pool hayward pump
Dont run pump any longer. Could damage it further. Recommend overhaul at qualified well established pool repair shop. If unset of noise suden probally somethign stuck. If onset of noise gradual probally bearing. Kirk
Feb 14, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward 1.5 Hp Northstar High Performance Pump Logo
741 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
