Question about Sharp AL 800 Copier
8% red light
Someone gave us this copier without the manual.. turn it on and a blinking red light comes on saying 8% and nothing more happens...any suggestions?
  • Anonymous Dec 21, 2007
    i need a n instruction manual
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Printer making buzzing noise when turned on, moving part that holds ink cartridges do not move, blinks red lights within eight seconds after powering on.
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 16, 2010 | Office Equipment & Supplies
Paper got stuck. I've opened all openings I know about and removed all paper I can see, but can't clear the error. Red alarm light is blinking.
Hello there Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Feb 12, 2010 | Brother HL 1440 Laser Printer
Erroru051
Canon MX300
Hi
It is ink low error U051
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Feb 07, 2010 | Canon MX300 Office All-In-One Printer
My printer is blinking orange lite
Hi there ok try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Jun 18, 2009 | Canon S400 InkJet Printer
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony Bravia KDL26S3000 TV
According to the service manual if the red light is blinking then the TV may need to be service. Since your TV is less then a year old, still under manufacturers warranty.
I would suggest to contact Sony to ask them for the nearest authorized service center to have the tv repair.
Good Luck.
Jan 07, 2009 | Televison & Video
Red light flashes 8 times
i dont know the error code but my standby red light is blinking 8 times
Feb 10, 2008 | Sony BRAVIA KDL-40V3000 Television
Re-assemble Canon Ip2000
Hi there try see if this will work
Reset ip2000
1. Turn off printer
8. Your printer should respond as normal..
Nov 10, 2007 | Canon PIXMA iP2000 InkJet Printer
Sharp AL 800 Copier Logo
100 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
