Question about Riso RZ220 Duplicator
Risograph RP 3505 error code T05-604
The system error code comes up T05-604 and tells me to push the reset button. Nothing happens. Any solutions?
  • 2 more comments
  • bill221 Sep 29, 2009
    I tried this but it does not help. The power button is a switch and cannot be held in. Any more ideas?
    The power button is a switch and I cannot hold it in. Help.
  • bill221 Sep 30, 2009
    The machine does not have trays like a copier. Also, I can not get the drum out. Any more ideas?
  • bill221 Oct 01, 2009
    We finally found the problem. It was a blown fuse. Thanks for your suggestions.
    President:
  • 1,462 Answers
THis this might be a issue with the fuse, try changing the fuse and it might solve your issue,,
Please leave me comment , if you need further assistance
RNJ VINODKUMAR
Posted on Oct 01, 2009
  • 11,896 Answers
Disconnect for 8 hours. Meanwhile press the power button while unplugged, wait 20 minutes and plug back in.
Posted on Sep 30, 2009
  • 3,741 Answers
First of all check for any paper jam in the machine.open the trays and properly check out. -----------Press both right-hand side (Rest & Stop) buttons. --------------- also try this method for resetting the machine by switcting off and then holding down 2 top right hand buttons and switching on machine, let go buttons then switch off and on to leave service mode. ------------ check out.thanks.keep updated.
Posted on Sep 29, 2009
  • 3,051 Answers
Hello there:
if you do not have your manual to refer to the troubleshooting section
what you can do is to first remove all of the paper and if it has a ink cartridge remove it. now press the reset button and hold it in and unplug the unit at the same time hold in the reset button for 1 min than press the power button and hold it in for 10 seconds and release now plug in the machine and turn on the machine and it should start up and tell you to load the paper and the ink ok so do this and you should be ok?
if not please let me know and i will get some morre informatin for you ok?
best regatds Michael
Kenmore Elite Model 665 dishwasher won't start. The lights on the panel come on but nothing happens.
If you hit any 3 buttons in sequence your unit will go into diagnostics and tell you what the error code is
May 10, 2014 | Dishwashers
White stripes on copies
Looks like some dots of the thermal head are defective. So the master at these dots cannot be punched.
Sep 28, 2012 | Riso RP 3700
Mitsubishi rear projection tv.. 55 inch made in june 2003... will not turn on... no lights blink nothing no sound.. push button nothing happens.... looked in back not knowing what to look for or look at...
IF power light on front comes on for a second or two and goes off do the self check this set has:
On front of set when power light goes off, press and hold both the Input and Menu buttons at the same time for more than 5 seconds and release both buttons.
Power light should blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat the code four more times.
If this information helps and you want to know what error code found means rate this solution as very helpful and comment here and I will tell you what it means.
SD TECH
Aug 22, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Risograph: set master disposal box in place warning won't go away
sounds like the sensor is stuck when you put the box back in make sure it is square and sometimes if you open the front door whilst replaceing it the close rhe door after the reset can work check the sensor arm .. this hangs down in the middle where the box goes back in on the face plate of the side of the machine
Jul 30, 2009 | Riso RZ220 Duplicator
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Risograph rp 3100 ui
Reset machine... and check connectors to the boards... its a communications error to the digitizer cpu
Oct 13, 2008 | Riso RZ220 Duplicator
Riso RP3100EP risograph T01-520 SYSTEM ERROR
riso rp 3100ep electric paper tray not going all the way down properly, Please help!
Apr 22, 2008 | Office Equipment & Supplies
643 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
