Question about X-10 PROB60 60M Hz Oscilloscope Probe Selectable X1 , X10 Microphone
Have TDS320 SCOPE that powers on ok , but no panel control func.
Have TEKTROIX TDS320 SCOPE that powers on ok with traces present. But no leds illumiate on front panel, hence no control function via any knob on panel ? Wondering if supply volts to this panel has failed ? have no circuit diag to trace wiring!
    President:
  • 1,187 Answers
Are any knobs in manual position? Rotate all knobs full clockwise / counter-clockwise and lock in place.
Posted on Sep 29, 2009
No power o front panel no led radout no 110 or 220 or weld out put
Check switch continuity inside the control panel.Check all the switches.
Sep 02, 2014 | Miller Trailblazer 302 AC/DC Welder...
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
Machine will not power on
Possible failure of the main control board , remove the power and trace power to the control panel, if power is present then it is failure of the board, if not check the power cord, plug or inlet.
Sep 27, 2013 | LG Washing Machines
It wont switch on
Please try and check the mains outlet for the power. Next you can trace the continuity of the wire from the plug to the main control panel. Assuming this has an electronic panel there is a power supply within and must be checked to supply the low power to the processor control circuit. if absent check the power supply. If present check the processor and allied circuits or the controller board is faulty.
May 04, 2011 | Washing Machines
LED display is blank. No lights on display panel. There is power present at rear terminals. Machine stopped part way through wash cycle. Any thoughts? Thank You.
Possible that there is line break to the panel board.So firsst you must check this out before we can go further.
If no power check the wire for break.
If power is coming in to the board , check fuse, if fuse blows it ispower issue,failure in the power circuit.
If power is Ok , then the processor controller is defective.
Might have to replace the board then.check cost and proceed.
Hope this helps Good day
Aug 18, 2010 | Washing Machines
Don't have manual and I am not sure how to connect the power switch, reset switch, power LED and HDD LED
if you do not have the manual it's here.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=260
those leads go on pins that are together usually by one edge of the board.They are hard to see but are marked.you should be able to see the reset and power switch quite clearly and if the leads are not lablelled then trace them back to the small reset switch and the power on switch
Jul 06, 2010 | MSI K9VGM-V Motherboard
Tektronix scope TDS 320 GOING,BUT NO COMMUN .VIA PANEBUTTONS ?
The Tektronix TDS series are notorious for the electrolytic caps drying out. They are SMT components and hard to replace if you do not have the proper equipment. Replace all of these on the main board ad all of your problems should be resolved. Good Luck!
Mar 20, 2009 | X-10 PROB100 100M Hz Oscilloscope Probe...
Coleman 15k will not come on
Here is the troubleshooting guide for your unit. Hope this helps.
TROUBLE SHOOTING GUIDE
TROUBLESHOOTING
Symptom Remedy
1. Remote does not turn on system
- Check and replace remote batteries if the display fades while
any button is activated or no display is present. - Point remote towards IR receiver during transmission. 2. System does not turn on, no green LED & no beep
- Check wiring. (see "installation instruction")
- Check modular cable to receiver.
- Check diagnostic LED status in the upper unit control box.
3. System does not turn on even when receiver green LED is on.
- Low or over voltage condition, check diagnostic LED status in the upper unit control box.
4. Fan runs but no cold air.
- Evaporator temperature sensor reaches low limit, defrost mode.
5. System runs continuously in the cool mode
- Remote was set for "I feel" mode and is left in a heated environment (sun etc.)
6. System runs continuously in the heat mode
- Remote was set for "I feel" mode and is left in a cool environment
1. Diagnostic LED (green)
(Note: Located on the control board in the upper unit control box.)
a) The LED is on when the 12VDC is adequate and communications are
present.
b) The LED is flashing fast and steady when in the freeze mode. Evaporator has frozen and the freeze proctection switch is engaged.
c) The LED is flashing slow and steady when the delay on break timer is
activated.
d) The LED is flashing 1 cycle on and off for one second with high or low
12VDC. Check the incoming 12VDC power for OK.
e) The LED is flashing 2 cycles on and off for one second with a
communication problem. Problem with the control board in the unit and the remote.
Hope this helps.
Jeff
Rate me Please!!!
Jul 29, 2008 | Coleman Mach 15 Air Conditioner
I have a Sole Control SC-545 and would like to know how to program so will work with my Zenith TV
CURTIS Universal Remote Control setup
  1. Turn ON your TV.
  2. Press FUNC button.
  3. Press TV button.
  4. Enter 2-digit code No. (either 01 or 05)
  5. Press TV button.
  6. Press POWER button to confirm.
Search Mode Method
  1. Turn ON your TV.
  3. Press TV button.
  4. Repeatedly press POWER button until TV go's OFF.
  5. Press TV button to confim.
Red LED will blink 3 times if wrong input is detected.
Jun 26, 2008 | Televison & Video
X-10 PROB60 60M Hz Oscilloscope Probe Selectable X1 , X10 Microphone Logo
298 people viewed this question
Top X-10 Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a X-10 Audio Player and Recorder Expert? Answer questions, earn points and help others
