Question about Canon PIXMA MP190 All-In-One InkJet Printer
Cannon Mp190 no escanea
He estado tratando de escanear con mi Canon Pixma MP190, pero no hepodido. Me sale un cuadro de error: ScanGear: Mantenimiento deimpresora en curso. Realizar exploracion al concluir. Code: 2,114,
(Nota: las cartuchos no se encuentran instalados aunque no se necesitan para escanear logicamente)
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
Ubicacion de rele de bomba de gasolina
Hola, An?nimo Me encantar?a ayudarte con tu pregunta de moto, pero debido a la magnitud de la llamarada solar de ayer las bater?as de mi bola de cristal est?n muertas y mis circuitos de auriculares de telepat?a mental se derritieron. Necesito el a?o, la marca y el modelo de su motocicleta, por favor haga clic en la palabra "COMENTARIO" a continuaci?n y proporcione esta informaci?n en el cuadro que se abrir? y luego haga clic en el cuadro de comentarios verde en la esquina inferior derecha despu?s de que los mensajes I Recibir? un icono de "ALERTA" que me permitir? responder a su informaci?n. Buena suerte y tener un d?a maravilloso.
Jan 27, 2014 | Honda Motorcycles
Mi video camara es canon Dc210 DVDcamcoder no acepta los DVD que le pongo de ninguna que puedo hacer
El manual dice que algunos discos no vas a funcionar con la cámara, pero por supuesto no hay nada en el sitio de eso.
Yo sabía acerca de un problema similar, ya que estaba tratando con los discos DVD + RW. He encontrado algo la solución en la web de Canon: DVD-R/RW y DVD + R / RW son similares, pero en general los formatos no interchangable.
Las videocámaras Canon DVD sólo utilice discos DVD-R/RW. DVD-R/RW y DVD + R / RW son similares, pero en general, los formatos no interchangable. Las videocámaras Canon DVD sólo uso * DVD-R/RW o DVD-R DL (DC10, DC20, DC100, DC40 y no son compatibles con discos DVD-R DL). Si un disco DVD + R / RW se carga en una videocámara Canon DVD de la videocámara mostrará un mensaje "Error de Disco" después de que intenta leer el disco.
* Discos DVD-R de doble cara también se puede utilizar sin embargo, cada lado deberá ser inicializado antes de su uso.
Espero que esto le sea de ayuda; recuerde calificar esta repuesta. Suerte.
Sep 26, 2011 | Canon DC210 DVD Camcorder
Tengo una mac version 10.6.6 y no puedo escanear a mi escaner snapscan 1212
Perdoname, por favor, porque hablo espa?ol, pero no hablo de problems con tecnolog?a...
Puedes encargar 5 archivos para installar SANE en tu computadora. Es un met?do como TWAIN que las computadoras pueden usar para comunicar.
Despu?s de installar los archivos de SANE, puedes usar Graphic Converter 7, una utilidad para convertir y editar fotos. Se puede excanear usando los mandatos Scan>Scan with Image Capture... Cuesta $39, pero se puede usar grat?s por un rato.
Tambi?n se puede usar VueScan. El programa cuesta $39, tambi?n, pero es un programa para escanear solamente. No puede hacer m?s, y hace dos semanas o un mes que se puede usar gr?tis (lo siento, no recuerdo).
¡Buena suerte!
Feb 24, 2011 | Agfa SnapScan 1212u Flatbed Scanner
Hola mi proplema es cuando ase mucho frio mi veiculo no levanta el compresor si trabaja pero no sube despues lo apago por 10 min y levanta pero despues si la manejo en el trascurso del camino se va bajando...
cambie los levelers o los solenoids si eso no arregla su problema remplase su air suspension con un conversion kit para poner amortiguadores de resorte yo me ahorraria todo ese dolor de cabeza y mejor cambiaria todo a resortes en ves de gastar tanto dinero en sensores y bolsas defectuosas yo cambie mi suspension completa y ya no eh tenido ningun problema busquelos en strutmastercom cuesta al rededor de 800 dolares pero va a gastar mas tratando de remplasar todo lo que esta mal con su suspension espero y esto sea de ayuda para uds
Feb 10, 2011 | 2003 Lincoln Navigator
Cannon pixma MP190 wont print - replace ink cartigages - errors 5 and 13 showing up on LED. help. Used genuine cannon cartigages. Checked all cables etc.
Were the cartridges new? if they were used they would need to be reset. Also you can go onto the Canon website and that should help too.
Sep 01, 2010 | Canon PIXMA MP190 All-In-One InkJet...
RAFRIGERADOR SAMSUNG SRS20DTD
Estoy en los Estados Unidos, pero quisiera ayudar. Llamé Samsung, pero no tenían ninguìn Info en esta unidad extranjera. Llame por favor:
A CENTRAL TECNICA (SERIN)
CLL 70 # 16 - 43 BOGOTA, CUNDINAMARCA 6001272
B HOME SERVICE DE COLOMBIA LTDA
Cll 24 No 68H - 24 sur BOGOTA, CUNDINAMARCA 6001272
C SERVICE SOLUTION E.U.
AV CLL 116 NO 70C-28 BR. POTOSI BOGOTA, CUNDINAMARCA 6001272
Jul 17, 2008 | Samsung SRS20DTD Side by Side Refrigerator
Un problema con webcam
como puedo hacer mi driver se me a extraviado como mi maquina tuve que formatearla ahora como hago para instalar mi wed cam
Jun 16, 2008 | Computers & Internet
Error 5700 displayed on copier screen
i forgot to mention that my printers a pixma MX700
Jan 06, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA MP190 All-In-One InkJet Printer Logo
914 people viewed this question
old marine
old marine
