Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
What does it mean when the washer says oe or ie
    President:
  • 1,776 Answers
The "IE" code indicates a water inlet problem. This code is generated if the correct water level isn't reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes. I would look at the water inlet valve first regarding this code. Unplug the machine, shut off the water and remove the supply hoses. Check the small metal screens inside the valve and make sure they are clear of rust or debris and check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity will mean a bad solenoid. I'll attach a photo for reference.
The "OE" code indicates a drain problem. This code is generated if the water is not fully drained within 10 minutes. Check the drain hose for kinks or obstructions. Sometimes running a hot wash cycle with about a 1/2 cup of vinegar will clean out any sludge buildup in the drain hose. If this doesn't correct the problem, then the next thing to check would be the pump. I sure hope this helped and best wishes.
Posted on Sep 29, 2009
Thanks canbruce75 for the clue on the OE error. Ours is a little different - a model wm227hm. The key to resolving this issue for us is a little door on the bottom left at the front. Flip this down and you'll find two black circles. The little one is a drain hose with a plug in the end. Remove the plug and the water will drain out. Be patient, there is a lot. It took about 40 minutes for me to get it all. Once that's done, unscrew the big circle plug. That's where you will find lots of crud. Probably smelly crud. Clean that out and you will probably have solved the problem without having to look at the pump.
Posted on Oct 05, 2009
3 Suggested Answers
dblred
  • 68 Answers
SOURCE: WHAT DOES "OE" MEAN
if it is running water, even if the washer is off, then the solenoid is stuck open on the valve. the best solution is to replace the fill valve. but sometimes you can take the valve apart and find sand or a small pebble causing the solenoid not to close, and fix the problem that way. let me know if you have any further questions. good luck, shane.
Posted on Sep 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: What does OE mean on a Hitachi washer??
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Lg washER AND DRYER. What does OE mean
AN OE code means that the Front Load Washer was unable to drain water.
Jan 11, 2017 | LG Washing Machines
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
Kenmore Elite He washer code "OE"
The 0E code means the washer won't drain. It is usually a problem with something obstructing the pump, a kink in the drain line or the pump is burned out.
Jul 26, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
OE code but will not drain and spin
LG Error quick list. Print it and post it near the washer:
IE: Water level
UE: Imbalance
OE: Drain problem
FE: Overflow
PE: pressure sensor
dE: door error
LE (with a a slash in the
middle of L. Thermister out
CE: Over amping
LE: hall sensor short
bE: Ball sensor loose connection
EE: eeprom out
PF: power failure
My Freebie manuals and repair notes are HERE
Dec 23, 2010 | LG WM2455 Front Load Washer
What does the flashing OE mean? My washer is flashing OE and the water will not drain after the cycle.
OE means the drain hose is clogged. UE means unbalanced or overloaded. This is decribed in the owner's manual page 31-32. Pull the hose from the back of machine and rinse it out. Then, check the lint filter on the bottom, front left side. Put drain hose back and close lint filter. Unplug the machine, press and hold the start button for 10 seconds to reset machine computer (not the on button...leave machine turned off and unplugged while resetting computer) plug back in, put on no spin and start the machine. It should drain.
Jan 20, 2010 | LG WM2487H Front Load Washer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
LG WM-2032HW front loader washer gives error goes OE and IE
"OE" is really "DE"= drain error. Clean out filter behind access door on lower left corner front panel of machine. (there will be some water in machine)
"IE" = inlet error. machine took too long to fill. clean out inlet water screens where the hoses connect onto machine.
Oct 02, 2008 | LG Washing Machines
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
Washing Machines Logo
503 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
