Question about Dell 924 All-in-One InkJet Printer
I too cannot print using black ink cartridge. Someone help..plz
My printer was disconnected and when I reconnected it and tried to print, some box came up about print options and I guess I chose the wrong answer (yes or no?) but now my black and white print option box is closed. I can no longer select it and can no longer print from my black cartridge, only my color. Does anyone know how I can get this button back and stop wasting my color ink? (Please help.)
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    Hi there, I have a hp officejet 6310 all in one: I changed the black cartridge but it brings up an error message that the black ink is finished. Please help:(
    Hi
    Please try this solution.
    Remove the USB cable into the printer and leave the printer on.
    Remove all the cartridges.
    Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
    Disconnect the power cable and from the power source supply.
    Now open again the printer door. Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
    Reconnect power cord and turn on the printer.
    Return all the ink cartridges and close the door. Wait for the calibration process.
    Print the test page to check if it working.
    Reconnect the USB cable and try to print again.
    Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
    May 12, 2011 | HP Officejet 6310 All-In-One InkJet...
    My printer does not appear to be printing from the black cartridge. I have tried via the maintenance to clean the heads, but when I print it continues to not print. I have also replaced the cartridges.
    Hi
    A hard reset of the printer may clear the error. Here is how to perform the hard reset:
    1.Shut down the computer.
    2.Open the top cover of the printer and remove the print cartridges.
    3.Close the top cover of the printer.
    4.Press the power button on the printer to turn the printer off.
    5.Disconnect the communications, (USB or Parallel), cable from the back of the printer.
    6.Disconnect the power cord from the back of the printer for one minute.
    7.Reconnect the communications cable to the printer.
    8.Reconnect the power cable to the printer.
    9.Press the printer power button to turn the printer on.
    10.Open the top cover and reinsert the print cartridges.
    11.Close the top cover and print the calibration page.
    12.Restart the computer. If not working, try to clean the ink head manual by removing the cartridge and rub the ink head to a plain paper with alcohol until ink flows on the cartridges and then run the print nozzle or print alignment page. Please let me know if you need more help. Please rate this solution if you find it helpful to you and might help others as well. Regards
    Mar 01, 2011 | Canon PIXMA MP830 All-In-One InkJet...
    I put in fresh black ink jet cartridges in and I am positive they are in correctly yet it will not pick up black print numbers ect.
    When the ink cartridges were installed there is a possiblity that you have not used the procedure to replace the ink.
    hence there is a chance that the software is having a conflict.
    Disconnect the printer and uninstall and then reinstall the software of the printer. Then reconnect the printer to the PC .The hardware will be detected and installed. Now make a head cleaning and do the test print.
    If this wont help, it is possible that the printer's head is faulty.
    Hope my advice helps.
    Aug 21, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
    My HP C5180 All-In-One printer says full ink cartridge is empty
    Hi!
    There are two ways to make your cartridge work again.
    The first one will be basic....turn on the printer...remove the black cartridge from the printer.. using a moisten cloth, clean gently the contact terminal of the cartridge..after letting it air dry for a couple of seconds return the cartridge.. then try printing again..
    The second one is to reset the ink cartridge.. how?
    1. While your printer is on.. disconnect the usb cable from the back of your printer.
    2. Remove the cartridges.
    3. Wait until the message "Insert Cartridge" display on the control panel.
    4. Disconnect the power cord from the back of the printer.
    5. Wait for 60 seconds.
    6. Plug the power cord at the back of the printer...If printer does not automatically on..press the "Power" button.
    7. Reinsert the cartridge and close any open doors of the printer.
    8. If prompted to Calibrate, do so..
    9. Reconnect the usb at back of the printer...and try printing again..
    After that you can print easily.
    If you find this information helpful....Please rate this solution and vote on this on the YES below..thanks..
    Jun 02, 2010 | HP Photosmart C5180 All-In-One InkJet...
    New cartridge inserted, received error
    Hi can try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
    Reset the product:
    1. Without turning off the product, disconnect the USB cable from the rear of the product.
    2. Remove the cartridges from the product.
    3. Wait for the 'Insert Cartridges ' message to display on the control panel.
    4. Disconnect the power cord from the back of the product.
    5. Wait 60 seconds.
    6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
    7. Reinsert the cartridges, and then close any open doors on the product.
    8. If you receive a prompt to print a calibration page, do so.
    9. Reconnect the USB cable to the rear of the product, and then try printing again.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Apr 03, 2009 | HP Photosmart 3210 Printer
    Black Cartridge Not Being Used While Printing
    try printing in monochrome mode or gray-scale mode, and specify that it use only the black cartridge.
    another problem could be that the head have gotten dry, remove the cartridge, get a soft cotton towel, wet it with a little bit of water, put the head of the cartridge (where the ink comes out from) on the cotton towel, you will see some ink come out of the cartridge, if yes, then put the cartridge back into the printer, and give it a try.
    if not try to blow some air into the cartridge as if doing CPR ;) to the cartridge, this will help the ink get out of the cartridge.
    if all this fails, get a new cartridge, as sometimes the head could have gotten damaged.
    good luck
    Mar 25, 2009 | Dell A940 All-In-One InkJet Printer
    HP Officejet 7110 won't print black and white w/o color cartridge. I never print in color; yet the machine will not print in just black and white without having a color cartridge with ink in it. Why would...
    I've used HP Inkjet/Officejet printers for years. Many HP inkjet printers also use the color cartridges to some extent to create 'black' in slightly different shades, that can be un-noticeable to the eye.
    To print using only black ink, try doing as follows:
    When you click on 'Print' from your browser, the printer properties (or preferences) page opens.
    You must first set the printer to not print in color (color is the default setting). Then you must set the printer to use 'black ink only' by using the 'advanced settings' as follows:
    1. In most browsers there will be a box on the lower right of the printer properties page that says 'advanced'.
    2. Click on that box to get the advanced settings page to open.
    3. Once open, the feature you need to check is called 'print in grayscale'. (It is usually at the top of the list) It is set to 'off' by default. Just click on it and a menu box drops down and one of the choices is 'Black Ink Only'.
    4. Click on that and then 'save' or 'apply' those settings.
    Then your printer should be using black ink only.
    You will probably have to set that each time you want to start a new printing job, as the default settings on these printers are tilted toward using the color cartridges in order to sell you more colored ink.
    Also, if you are using Windows 10 and the 'Edge Browser' that comes with it, you cannot get to the 'grayscale' option. So either use a 3rd party browser, or use good old Internet Explorer, (which is still included in Windows 10) to open and get to the page you are trying to print.
    I hope this helps. If not, go to HP.com and type in the model number of your printer and then do a search from there for detailed instructions for your printer model (which might be slightly different than what I have shared here.
    Apr 28, 2017 | HP OfficeJet 7110 All-In-One Thermal...
    The 3 yellow lights are blinking and cannot be shut off.error:oxd0840001 isdisplayed.
    Solution Use the instructions below to resolve the issue by restarting the product.
    1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
    2. Open the cover of the product and remove the print cartridges.
    3. Close the cover and wait for the Insert Ink Cartridges message to display.
    4. Disconnect the power cord from the back of the product and wait for one minute.
    5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
    6. Open the cover and reinsert the print cartridges.
    7. Close the cover. If prompted, print a calibration page.
    8. Reconnect the USB cable, and try to print a print job from the computer.
    If these steps did not resolve the issue, contact HP technical support for assistance.
    Apr 19, 2008 | Office Equipment & Supplies
    Unable to print using black printer cartridge
    Well, Yeah mine did the same thing!!
    And I got soooo fusy! and etc. But yeah okay go to the manul script and look for the ink Number then once you find the ink number go and buy the ink that has the same number of ink as yours!
    Then,
    Once you get home replace it with the others.
    BUY THE BLACK INK! not the TRI-COLOR!
    Sep 25, 2006 | Dell A920 InkJet Printer
    Dell 924 All-in-One InkJet Printer Logo
    61 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    Electro Med Services...
    color wheel light...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
