Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
CIRCUIT BREKER KEEPS TRIPPING - Mitsubishi Mr. Slim MXZ30TN Air Conditioner
  • 396 Answers
Your house wiring in not capable of powering the unit. Try a different location to plug in. Check the unit to make sure it is not faulty and will trip breakers because it is damaged.
Posted on Sep 29, 2009
My wadher keeps tripping a circuit breaker
hi
the reason it keeps tripping is either over loaded / short circuit due to cracked insulation cable / water withing the electrics .or and the insulations to the electric motor is broken down
Oct 22, 2017 | Electrical Supplies
I have a dehumidifier model AHM65LKM1 65 puts when I turn machine on it keeps tripping
Dehumidifier tripping AFCI - DoItYourself.com Community Forums
www.doityourself.com > ... > Electrical - AC & DC
Oct 1, 2011 - My dehumidifier is on a 15 Amp circuit with an AFCI breaker. ... What I mean by that is that it can run without tripping for days or only a few hours ...
Sep 27, 2015 | Dehumidifiers
My fridge keeps tripping the power
Your solution is one of two things.
First is the circuit you have plugged the refrigerator is either over its limit and the breaker is tripping because it is overloaded. In this case you will have to determine what load also share this circuit and eliminate the extra loads or move the cord to another circuit which is not overloaded. Most home circuit are wired with 14 gauge and is rated at 15 amps. When the circuit gets to 15 amp and more, the associated breaker trips to prevent overload.
Second, Your refrigerator may have a short and needs troubleshooting to find the cause. To see if it is a bad circuit try plugging into a circuit via extension cord to circuit in another room receptical. The reason I say another room, when electrical installers wire circuits, you can put several recepticles on the same circuit. If you plug your refrigerator in the same circuit you had it on before then you will get the same problem, your refrigerator tripping again. If your frig trips on a different circuit then troubleshooting the cause will normally require a tech.
Good luck and hope this helps.
Oct 28, 2014 | Refrigerators
Kemore elite dryer keeps knoting the breaker
Here is a tip that I wrote that will help you ti find out why the circuit breaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Oct 03, 2010 | Kenmore Dryers
SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
heatman101
Jun 24, 2010 | Friedrich SL24J30 Air Conditioner
Keeps tripping the breaker
What size breaker?
as long as there are no other appliances or anything on the circuit a 15 amp breaker will do...if you have alot of other items on that same circuit you either need a larger breaker, or use a different circuit all together
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Mar 31, 2010 | Gold Medal 2656 Ultra Popcorn Maker
Dryer trips circuit breaker
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
Double oven keeps tripping circuit breaker
heatman101
Oct 24, 2009 | Jenn-Air JJW9830D Electric Double Oven
15 Amp circuit breaker keeps on tripping , as as
breaker tripping right of way means bad breaker or dead short. which means something has burned out or is wired incorrectly
May 13, 2009 | Heating & Cooling
Breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Sep 11, 2007 | Heating & Cooling
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
174 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
