Question about Kenmore 62602 Electric Dryer
When i hit the on button I get nothing! 80 series electric dryer.
    President:
  • 1,776 Answers
Check for a blown thermal fuse. It is about an inch long and is usually inside the rear of the dryer, attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 29, 2009
try jumping the start button out on top if thats it ,replace it
Jan 15, 2013 | Kenmore Dryers
Kenmore series 80 electric clothes dryer suddenly, the dryer won't start. hold the button in and nothing happens except the timer sounds like it is running. release the button, nothing.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 30, 2011 | Dryers
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
I have electric series 80 kenmore, all of a sudden it wont turn on, still getting power because light is on when door is closed. turns off when door opened. hit button and nothing happens at all.
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Dec 13, 2009 | Kenmore 63942 Dryer
Heavy duty super capacity plus Kenmore 80 series Electric drier the timer is running, but when I push the start button - nothing
the drum belt may be broken. you will have to check this, it goes around the drum and the pulley on the motor. you could also have a bad motor.
Oct 16, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 series electric dryer wont start
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
Jul 22, 2009 | Dryers
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore 80 series dryer will not turn on
check the door switch,also you can remove the back and check the main white fuse,i think it's one of the two-mike
Feb 27, 2009 | Kenmore 65924 Electric Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Kenmore 62602 Electric Dryer Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
