Question about Honeywell 5804 Ademco Wireless Security watch
Honeywell 6160 keypad display not powering up.
I have a Honeywell 6160 keypad for an alarm system and the display does not power on. I do know it is receiving power because the keypad buttons are lit up. Is there a wrong connection somewhere or is the keypad defective?
I would check the connections first
Posted on Oct 14, 2009
Security code program for ademco alarm 6150
6150 is the type of keypad you have the alarm system itself. The 6150 works on a number of different Honeywell panels. You need to locate the main metal box and open it. There should be a white sticker on the board with the panel type. (Ex. v10,v20, Vista...)
Oct 21, 2011 | Honeywell 5804 Ademco Wireless Security...
How do I add a code to my honeywell keypad 6160 for my pet sitter to use
Codes are programmed into your control panel, not your keypad(s). The 6160 keypad can be used on many different control panels, and how to program codes is different for each. First find your control panel in a beige metal cabinet and look at the model number. Then use your favorite search engine with the phrase "Ademco [control panel model number] user manual".
Jun 04, 2010 | Honeywell 5804 Ademco Wireless Security...
My lcd screen is blank and system doesn't respond to commands... Says ''not ready'' but that's it! There is power to the units but no response except a single beep after the pin and command is entered. It...
FYI 6150 is keypad model not alarm model. See if yhis helps. try pressing the " * " key bottom leftit thould then indicate zone trouble or fault. that sould give you at least some place to start.
Feb 07, 2010 | Honeywell 5804 Ademco Wireless Security...
Our Ademco 6160 PL3 alarm system keypad has an error message
It is located inside a tan colored metal box 12"wide by 15" tall and 4" deep; unless it is flush mounted, then only .5" deep. inside you will most likely find a 12 volt 4 or 5 or 7 amp hour battery. Note; the door may have a lock on it. I have found the key on top of the box, in the lock, and unlocked. The box could be located anywhere but, many times in closets, utility rooms, garages, crawl spaces, etc.
Nov 01, 2009 | Honeywell 5804 Ademco Wireless Security...
How can we use the Honeywell alarm LYNXR series without the service if we dont know the installer code. Where would the code be found anyway?Thanks
you have get into programming by disconnecting the power then reapplying it (battery first) within30 seconds press1and 3 ( same time ) until you see 20 flashing. press #20 and the installer code will be displayed one number at a time. If you want to change it press *20and whatever 4 digit code you want the installer code to be. Next Press *99 The system will reset and come out of programming
Oct 22, 2009 | Honeywell 5804 Ademco Wireless Security...
Honeywell 6160 need to change passcode?
6160 is model of keypad the person answering this question will need system type located in control box.
Oct 15, 2009 | Honeywell 5804 Ademco Wireless Security...
Need to know which pole is positive and which is negative for honeywell transformer for alarm system (120VAC 60 HZ .30 AMPS)
If it is a VISTA or a LYNX then it doesn't matter as the transformer puts out AC current instead of DC. This is done so you can have very long wire runs of very thin wire without causing problems.
Think of your house power, it comes from the high tension lines over many dozens of miles and they power entire city sections (AC-Power). But if you're on DC (when the poles matter) such as in a car, you'll then need a HUGE wire just to run a subwoofer amplifier by itself. Yet power tools can run on a 50' extension cord that's 1/4 the thickness and be fine! the AC power delivery is much more efficient in that respect, and alarm systems usually have wire runs that span the whole house and they're usually all around 18 to 22 guage wire (very thin) to save on installation costs...
Jun 23, 2009 | Honeywell 5804 Ademco Wireless Security...
Ademco Vista 20 programming
You need installer programming manuel.Yes to stay instant.
Feb 24, 2009 | Honeywell 5804 Ademco Wireless Security...
Honeywell 5804 Ademco Wireless Security watch Logo
431 people viewed this question
Top Honeywell Watches Experts
Jimmy Accardi
Are you a Honeywell Watch Expert? Answer questions, earn points and help others
