Question about Denon AVR-1907 Receiver
I have had my Denon AVR-1907 for about 20 months. About two months ago, it started shutting down and the On/Off button blinks red. Almost all the time it would clear by itself for no reason and then work ok. Now, it is happening all the time I turn it on and cant use it. Speaker wires are not touching and the chassis is well ventilated. I have a main left/right, center channel, subwoofer, and two rear speakers. Help.
    Sniper:
  • 137 Answers
You will have to check with a volt/ohm meter the + and - 15volt regulator ics in the power supply if they are off by more then 3 volts it will shut down as soon as it is turned on,and you still will have a flashing red light. also you may want to check the output transistors for shorts if your regulator ics are good.
Posted on Apr 22, 2010
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
Denon avr-1513 shutting off and blinking red light
Sounds like you could have a bad speaker connection. Try disconnecting the speakers and see if it stays on. If so, connect one at at a time until it goes off to determine which one.
Jan 20, 2013 | Denon 5.1 Channel Receiver 1080p AVR-1513
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
DENON AVR 1507 short?
unplug it, let it set for about 15 min., plug it back in and see what happens. Hopefully it will recycle itself. If that fails, with your theater remote, you can pull up it's functions screen on your TV, and probably return it to factory default settings. That would be a last resort for me before seeking professional help. Good luck. . .
Jul 27, 2017 | Denon AVR-1507 Receiver
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
Whenever I start playing on my xbox or playstation, the receiver will shut off (the red light is blinking around the power button). Once I hit the button, it stops and then I can turn the receiver back...
does it only shut off on high volume or a loud noise?
It's the amp tripping to protect itself.
look out for a shorting speaker wire or faulty speaker etc. disconnect each in turn to find out which
Sep 03, 2010 | Denon AVR-987 Receiver
I just purchased a used Denon AVR-3200 and have nothing hooked up yet but plugged it in on my kitchen counter and upon turning the unit on, noticed the error overload button was lit up but the unit did not...
Hi
I've had an AVR 3200 for about 10 years - occasionally (maybe once every 6 months), the error overload button comes on... for no real reason than i can detect (ghosts in the machine, maybe)... rebooting has always fixed it for me.
Aug 21, 2010 | Denon AVR-3200 Receiver
Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Dec 25, 2008 | Denon AVR-1100 Receiver
Denon AVR-1906 Reciever is not working. Was watching a movie and then it suddenly shut off. Now, the power light is blinking red. When I try to power it on again it starts to boot up but then turns off...
speaker terminal are short circuit,switch power off connect speaker properly then switch power back.
-the ventilation holes of the set are blocked-turn power off and make good ventilation around leave the set to cool and turn power back.
-the unit is operating at continuous high power turn it of and allow for cool down and switch it back.
Jun 01, 2008 | Denon Audio Players & Recorders
Denon AVR-1907 Receiver Logo
441 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
