Question about Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F
Door will not close, magnetic strip won't adhere, and air does not **** door shut
  • 109 Answers
Change the magnetic gasket from a good service center or you may change it yourself. Thanks.
Posted on Sep 29, 2009
The left door isn't closing with the magnet. (It isn't a rubber hinge/strip problem) It is the bumper inside at the top which isn't gliding over the stop on the door side
Try cleaning both surfaces with a bit of dish detergent on a damp sponge, to remove any sticky stuff, then apply a burst of silicone spray. That's what worked on our fridge when the freezer door became balky.
Feb 22, 2016 | Samsung RFG237AARS 23 Cu. Ft. Counter...
Old whirlpool upright freezer. door left slightly ajar.light on inside. Rubber around door warm. won't seal.some things starting to thaw.shut door.should I do anything else
Seal needs to be replaced around door. Make sure magnetic strip is tight against sides of refrigerator, even if you have to cut the outside so it lays flat against the sides.
May 03, 2015 | Whirlpool Freezers
The light in my freezer stays on when the door is closed.
I am curious how you know it is on unless you get inside. Some have magnet switches that will not cycle until the gasket seals.
Jan 11, 2015 | Viking Freezers
Factory reset for electrolux appliance
in order to solve a problem you need to understand how the device works. ideal for sensing the status of appliance doors
whether in the open or closed state (or for internal light). in the door under insulation (not visible) is a permanent magnet which switch on or off reed switch (usually on electronic). when the door is closed, the permanent magnet close or open the reed switch, depending what kind of switch is, normally open or normally closed. electronic received that information and because that (open door) stop the cooling fan. so, in your situation i would like to check that door is not hung up for some reason or try use an external permanent magnet. of course, reed switch should be checked also, because sometimes contacts may remain closed.
see the pictures below,
factory-reset-electrolux-appliance-tfdolxcnkaipunda4diszd1y-5-5.jpg factory-reset-electrolux-appliance-tfdolxcnkaipunda4diszd1y-5-9.jpg dado
Jul 28, 2014 | Electrolux ICON Professional E24RD75HPS...
My freezer door used to **** shut now it easily pops open
What you are talking about sounds like the magnets in the door seal are weak.
Mar 10, 2014 | Frigidaire Freezers
Freezer door does not have the vacuum suction that it did have
Check the door is square to the frame and no shelves are sticking out stopping the door from closing properly. The seal should be magnetic and stick to the frame quite well.Check no metal strips have come off so the magnetic seal isn't attaching to the frame
May 20, 2012 | Frigidaire 20 cu. ft. / 566 liter Upright...
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 | Freezers
REPLACEMTN MAGNETIC DOOR SEAL FOR FREEZER NOT
freezer needs to be down to temp with door shut for about 1hour to build up vaccum
Sep 14, 2009 | Bosch Freezers
Reply - thanks
check the way that your loading the door anf make sure that the unit slighly leans towads the back.
Dec 27, 2008 | Freezers
Door seal
i wouldn't worry about vacuum seal. door gaskets contain a low powered magnet around the entire face for "contact" seal, id look into perhaps something placed on one of the shelves or door blocking the door from closing as tightly as you remembered. if you have a problem with that gasket. it would have to be physically ripped and where it didn't make contact you would have an influx of warm air resulting in ice balls forming inside door liner adjacent to seal
Mar 03, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Logo
320 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
