Question about Bazooka ELA300.1 Car Audio Amplifier
Red Led Light on My Bazooka Ela300.1
I recently hooked my ELA300.1 after it had been in storage for a while. I got all the wires hooked up and turned my car on and a Red LED light came on. I am using all of the same wires I used previously, and I have attached all wires where they were originally but i can not get the Amp to respond. Help
    Problem Solver:
  • 12 Answers
Your amp went into a " Protection Mode "
this happens if you have blown something inside like a IC or something... if the amp have been dropped or bumped then its very likely to happen ... Check and see if your fuses are ok, if not then it would be best to let it be checked by a expert if its a IC or a cap inside
Posted on Dec 19, 2007
How to i find out whats wrong with my bazooka tube i tried to hook it up to a car battery and car stereo out side but wont work ???
follow this steps and fix it. GOd bless you
  • Verify that the amplifier is turning on by looking to see that it is lit up.
  • 2
    Use a voltmeter to verify your power supply is a good 12 volts by touching the ground lead to you amplifier's ground screw and the positive one to the amplifier's constant power supply screw. Also verify that you have 12 volts coming from the remote lead wire which is usually a thin blue wire between the ground and constant 12 volt supply.
  • 3
    Look for the "thermal overload" light. It is usually a red LED on the side of the amp. If the amp feels really warm and this light is lit, the amp has probably overheated from being tuned wrong or turned up too loud and shut itself down to cool off.
  • 4
    Check the fuses on the amplifier. These can blow with extended use or during heavy bursts of use.
  • 5
    Make sure the "Gain" and other volume controls are turned up.
  • 6
    Confirm that the signal wire is still attached to the amplifier and has not come disconnected by vibrations in the car. Also check that the wires running out of the amp to the speakers are still attached to the amp.
Oct 27, 2013 | Car Audio & Video
I need to know how to wire a led scanner to an avital 5303. The light has a red pos, black neg, and yellow that says brake. i want it to come on when the alarm is activated
Forget the yellow wire. Its for wiring WITHOUT an alarm. Connect the red to a fused 12 volt and the black to the orange "ground when armed" of the Avital 5303.
Jan 21, 2013 | AviStart 5303 2-Way Security / Remote...
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
I have an MTX1000xd and two Bazooka RS104DV's what wiring config?
Parallel will give you higher output but if you're hooking up all 3 you better use some very thick wire.Are you hooking these up to amp(s)?Sounds like a fuse is going to blow eventually too.
Good luck bro'!
Jul 17, 2010 | Bazooka RS104 Car Subwoofer
Heats up
It's normal for amplifiers to heat up during normal operation. If you power up the amp and let it idle (no audio) for about 5 minutes and it remains cool, the heating (when listening at high volume) is likely perfectly normal.
let me know if you have any other questions.
Dec 19, 2009 | Bazooka ELA300.1 Car Audio Amplifier
My protection mode red light comes on right when i put the fuse in my power line, even when my cars off!!! is it that my ground is bad? ineed some help!! oh ya, lol, its a ela300.1 bazooka amp!
Check your ground most definitly!, Replace it if needed. Check your remote wire and power wire as well. And if none of this works, then you are having internal issues.
Aug 26, 2009 | Bazooka ELA300.1 Car Audio Amplifier
Csa300.1 bazooka 500 watts
sounds like you may have blown your sub...sheck the spyder inside of it and see if it is stiff..if the speaker doesnt seem too responsive when you press on it, its probably blown...
Aug 01, 2009 | Bazooka ELA300.1 Car Audio Amplifier
Bazooka auto amp
remote wire is the blue wire maybe has white stripe that runs into stereo run from there to remote on amp as far as bass knob remote its common 1/4 stereo jack or a phono plug (looks like a phone jack)
Apr 19, 2009 | Bazooka ELA500.1 Car Audio Amplifier
Bazooka BTA series self-amplified tube subwoofer wont' power on
the blue wire is called the remote wire will go to back of head unit also to a bule wire that will send 2 amps to turn on the speaker only when the head unite is on
Apr 18, 2009 | Infinity BASSLINK Car Subwoofer
LED Light is on, but no sound from sub at all.. Have double backed on all wires but still nothing! HELP!!
if you change amps and it goes on protection the speakers are blown causing the amp to protect try changing speakers
Mar 24, 2008 | Car Audio & Video
Bazooka ELA300.1 Car Audio Amplifier Logo
318 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
