Question about Amana PTC153B35AJ Air Conditioner
Excessive water dripping from Central A/C drian line
The drain line from the unit in the attic runs out under under the eave of the roof on the back of the house. I have never seen it drip hardly anything at all. In the last few days, it is really dripping pretty steady. There hasn't been any dramatic change in outside temp lately. Installed new carpet in house last week & change filters after install, then notice all the water dripping. The drip pan is dry in the attic. Any suggestions?
  • Ned C Cook
    Ned C Cook May 11, 2010
    OH OH. where is the water coming fromif not the a/c unit?
  • chelseaotterson Jul 03, 2013
    I have the same issue. The ac unit is on the roof and there is a pipe that runs down the roof and the water pours on to the garden. its 120 deg here in phoenix....
  • 22 Answers
Sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Posted on Sep 29, 2009
Residential reroof, 3 layers comp. is ice & water required over eaves & rakes ???
Probably not required unless an older home or low slope roof, but very easy and not expensive to do when re-roofing. When attics were poorly insulated snow would melt above the attic from heat lost from the house, then refreeze at the eave causing an ice dam. More melting water hits the ice dam then back up under roof shingles and felt paper.
It is not required, but your specific conditions could warranty it. If your roofer is recommending it I would do it.
Aug 28, 2011 | Jensen JER-422 Universal Remote Control
I have a Carrier central air unit in the attic. There is water dripping through the ceiling. There is a problem with the internal drain pan, as the unit drips a LOT of water into the emergency pan. There...
The internal catch pan is very time consuming to replace, especially since it is located in the attic. But before you try that, have you checked to see if the drain line is clogged with algae and that it has the one inch to one foot drop you need for proper drainage? Has you house settled throwing the slope off?
If you live in the South algae growth can clog you drain line. I would disconnect the drain line (have a bucket handy) and see if it is clogged. If you have algai growth then you need to treat with bleach to kill it off. You might also want to run a drain snake through the rest of the line to make sure that it is clear.
Jun 05, 2011 | Carrier 38CKC060 Air Conditioner
Why is water backing up in attic?
You have a clogged condensate trap and or line
Jun 30, 2010 | Goodman CLQ36AR49 Air Conditioner
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
I have water at the base of my bryan central air unit
CONDENSATE MAY FORM DUE TO AN IMPROPERLY INSTALLED DRAIN LINE,EXCESSIVE HUMIDITY, MANY CODE ENFORCEMENT REQUIREMENTS DICTATE HAVING A DRAIN PAN UNDER THE AIR HANDLER,LOW AIR FLOW MAY CONTRIBUTE TO WATER PROBLEMS, DOES WATER DRAIN FROM THE DRAIN LINE?
Sep 18, 2009 | Heating & Cooling
My frigidaire central ac unit and secondary water valve
Yes there is a problem the primary drain is clogged up with crud an your aux. drain pan is full and draining through the emergency drain line
FIND THE OUTLET OF THE PRIMARY DRAINLINE SHOVE A WATER HOSE IN IT TURN IT ON AND COUNT TO 10 AND PULL THE HOSE OUT WATER WILL COME OUT THEN LOTS OF SLIME THEN YOU ARE DONE REPEAT THIS PROCESS ONCE EVERY 3 WEEKS DURING THE SUMMER
Aug 11, 2009 | Heating & Cooling
I have a unit in the attic and another part outside. I can stand inside under the ceiling vent and hear water running. When the unit cuts off, the water sound quits. I'm afraid something is not draining...
Sounds like your drain has sagged from the heat in the attic. It then backs up in the pan and sloshes around from the air moving. Get up there and see if that is the case, if so support the drain line so water runs freely to outside. This is an experienced guess. Good luck!
Aug 04, 2009 | Heating & Cooling
ROOF TOP AC UNIT ON COLEMAN POP-UP LEAKS
Does water drip out of unit on the roof while running ? If you look under the unit on the roof, you should see one or two little drains sticking down., that may be plugged up. Piece of wire or something and poke in the holes on the sides of those drains to make sure they're clear. Usually there is a plastic/nylon pan on roof unit to catch that moisture, and drain it off. Could be overflow because of the plugged drains, or I have seen the odd one crack but not too much recently, mostly back 5 yrs ago or so they had a run of them.
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Amana PTC153B35AJ Air Conditioner Logo
1,269 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
