Question about Sanyo DP50747 50 in. Plasma TV
Will not power up, something popped yesterday, and it lost power and will not come on
  • 69 Answers
The fuse might have blown. Could be various reasons. Unplug the TV. Place the TV down on it screen (on a SOFT FLAT, UN OBTRUSIVE surface). Remove the back panel screws and the panel. There will be a fuse, it is likely blown. Replace it with a fuse of the EXACT SAME amperage (it will be stamped on the fuse [example 5A is a 5 amp fuse]). Replace the back panel and carefully tighten all the screws. Replace your TV on it's stand. Plug it in, and turn it on with the remote. If it works, great. If the fuse blows again, you have a more serious problem. Do not attempt to fix it yourself, it could create a fire hazard. Seek a repair shop.
Posted on Sep 29, 2009
Lose power
i am having same problem with my blazer. i was told it is my ignition switch
Dec 11, 2012 | Cars & Trucks
I have a 1996 Toyota T100. I recently had to replace the headgasket on the right bank.While doing so 3 of the lifters came off.I thought I had them in the right positions so I put the engine back together....
This may have resulted in a valve being too tight, if it idles smooth with no misfires it's probably something else that's causing the power loss. Listen to the exhaust when idling if something that sounds like a pop, pop noise there is a leaking exhaust valve and the compression should be checked or remove the valve cover and check valve clearance. The loss of power may also be caused by the timing belt being off a tooth so be sure the timing belt marks are correct.
Oct 27, 2017 | 1996 Toyota T100
Suddenly I am having problems getting into my Outlook Express e-mail accout. This is what I am getting. There was a problem logging onto your mail server. Your Password was rejected. Account:...
OK you need to set up you account details again, it seems yours have been lost? corrupted or something. Anyway that error has to do with the actual email server, send receive settings.
Below is a How To Do it.... http://www.microsoft.com/windows/ie/ie6/using/howto/oe/setup.mspx
You need to put you Email server details as shown in the tutorial,if you don't know them simply Google for the info.
Aug 11, 2010 | Microsoft Computers & Internet
My tv is 3 years old. I was watching it yesterday.Something poped and it went black. what is wropng?
A capacitor shorted (popped) in the power supply then the fuse blew (went black) unplug TV, remove back cover, look for power supply; follow cord to it; find small silver can with top bubbled (bad)
unsolder/replace; replace fuse. plug in turn on.
Mar 20, 2010 | Protron PLTV-32 Television
My truck has lost power and "pops" . Any ideas?
If it is a rhythmic popping it could be a broken rocker arm or something in the valve train. It would be pop ..pop..pop..pop or if it is one pop on acceleration I would look for lean mixture. Vacuum leak,Fuel pressure etc.
Dec 06, 2009 | 1997 Ford F150 Regular Cab
Car's dead. Doesn't pop start or jump start. No lights, nothing. Battery is taking a charge with an AC charger though. It started fine yesterday. However, it had started a new noise yesterday when I was...
It sounds like you have lost the electrical connection between the battery and the car. Without a voltage source, the engine cannot start or run.
First, check the ground connection with a voltmeter. You should have a direct connection between the battery negative terminal to the engine block. Then, look for positive voltage in the main fuse block and at the power post on the starter.
Nov 02, 2009 | 2000 Hyundai Elantra
AC Adapter on !ORIGINAL! XBOX (not 360)
this could be the case if you need to replace the ac adapter its called a figer of eight mains lead, but the problem could be something Else if you have lots of plugs on one socket this could case a problem with a short surge ruining to the xbox and popping the red button out try using the box on one power point on its own with nothing Else even if this means running an extension cable from the hallway or kitchen, if it pops again then look at the mains lead. if it does not pop is ur power point (plug/s where you have the xbox pluged in). i hope this help cheers
Feb 06, 2009 | Microsoft Xbox Console
Sanyo DP50747 50 in. Plasma TV Logo
333 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
