Question about Gateway MX6447 Notebook
The LCD screen on my Gateway M-6317 is dim. How
The LCD screen on my Gateway M-6317 is dim. How do get it to illuminate?
  • Gateway Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Posted on Sep 29, 2009
  • 69 Answers
Press and hold the 'FN' key and tap the key that has the picture of a sun and an up arrow (or some other similar picture that dictates brightness - there should be two different keys that affect brightness one to increase and the other to decrease). Once you have the brightness set to your liking quit tapping the 'brightness' key and release the 'fn' key
No backlight
A) Replacement LCD screen backlight could be bad.
Happens. Sometimes you get a bad part. (Bad LCD screen assembly, in this case)
LCD screen may not be the correct one.
http://support.gateway.com/s/Mobile/2008/GodzillaFX/2528410R/2528410Rsp2.shtml
http://support.gateway.com/s/Mobile/2008/Godzilla/2528407R/2528407Rmv.shtml
A screen Inverter, and an LCD screen; are a MATCHED unit.
B) Screen Inverter:
May be bad, or the Wrong one
C) You may not have the screen Inverter, connected correctly to the Backlight.
Connections aren't tight.
D) The Display Cable TO LCD screen connection may not be tight, or correctly connected.
I know the display shows graphics, but a poor connection of Display Cable to LCD screen, can make the Backlight dim out.
I'm betting it is a poor connection, or the wrong screen Inverter, or wrong LCD screen.
Regards,
joecoolvette
(Be shame to kick that laptop to the curb. Nice laptop)
Jan 07, 2013 | Gateway P-6860FX Notebook
Gateway laptop screen darkens after boot up
Have you updated a Graphic driver? Does it Dim on battery and AC? Look at power settings. Control Panel, Power. You could Rool-Back the graphic driver to see if that changes the problem. A Gateway mt6841 has Windows XP OS, right?
Nov 27, 2012 | Gateway MT6841 15.4 WXGA SHINY LCD SCREEN
My Gateway M-6307 has a backlighting issue. The computer works but the screen is really dim. External output works, but dim on the LCD. I have switched LCDs from another Gateway laptop...same results. I've...
Have u tried replacing or trying a different power supply? Sometimes when a power supply is going bad will not put out the right voltage for the internal switch to kick up the brighter setting. Therefore it still thinks its on battery mode. Test the voltage from the supply and compare it to the recommended voltage gateway suggest for that laptop.
Jun 24, 2010 | Gateway M-6307 Notebook PC
Fujifilm Finepix F30 compact digital, LCD is very dim.
its not a good idere to get them wet you know,
it could be repaired if you can strip it out and you may be lucky it could only need drying out to work again take care when striping it down dry it out in free air only dont apply ant heat to it
Oct 31, 2009 | Sharp Viewcam VL-AH130U Camcorder
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | Gateway MX7118 Notebook
Display problem dell c600
I've also had that, The FN and brightness I've not determined, as I changed LCD panels, however, components in the LCD screen can be swapped out, cable and inverter and backlight (<-very hard to do!!) and the ATI graphics board is mounted to the mainboard, for the C600 they are affordable
Dec 20, 2008 | Dell Latitude C600 Lcd LCD Display
Laptop screen illumination
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Nov 03, 2008 | Gateway SL9550-30165318 Notebook
Lcd screen light wont work
What you should do try a flexcable and see if that helps if not then replace it with the LCD.
Mar 23, 2008 | Sony Ericsson W600i Cellular Phone
Gateway Notebook MX6027 - Dim Screen
Sorry to say the monitor is poked try to use a external monitor because theyre not cheap to replace. These guys are good and most likely tell you the same!!!
Oct 02, 2007 | Gateway MX6920 Notebook
Gateway MX6447 Notebook Logo
345 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
