Washing Machines Logo
Posted on Sep 29, 2009
Washer won't spin or agitate
How can i fix my machine
Anonymous
Level 1:
  • Contributor 61 Answers
  • Posted on Sep 29, 2009
Anonymous
Contributor
Level 1:
Answers
61
Questions
0
Helped
13852
Points
91
Belt or coupler need replacing
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 • Washing Machines
2answers
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
1helpful
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
1helpful
Frigidaire stackable model FEX831CS0 won't agitate or spin
Hi Kathy.
If the washer does not agitate and spin, then the most common problem is the belt: Washer Drive V-Belt (part 28 in diagram 1)
If you can manually advance to spin but the machine does not agitate, then parts that may need to be replaced are the agitator:
Agitator (part 11 in diag 1) or the agitator drive in the transmission:Agitator Drive (pt.2 diagram 2)
To replace the belt remove the assembly at front top of the washer held by two philips screws and clips. Here description of replacement procedure.
Here Diagram 1
Here Diagram 2
Regards.
Ginko
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
33helpful
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
