Question about GE Refrigerators
My GE GSS25PGMF WW side by side freezer only is not working, fridge is fine
  • rcdo Aug 07, 2010
    Freezer not making ice, it was until I had to defrost it with a hair dryer model gss25pgmf
catriver
  • 878 Answers
SOURCE: GE side by Side Fridge
froggy, First check the back panel of the freezer section and see if you have a big frost build up. If so, you probably have a defrost problem, heaters more than likely. If there is no frost build-up check to see if the fan in the freezer (evaporator fan) is running. If that's ok, next would be the automatic damper. Have someone unplug the refer. Open the refer door and listen for the damper door to open when someone plugs the refer back in. If thats operational, next would be the thermistors, you would have to ohm them out to see if they are in range. Seldom is this the problem. Check these things out and get back on what you find. Catriver..post back.
Posted on Apr 04, 2007
SOURCE: fridge does not get cold
I had the same problem. The problem was my freezer was not defrosting itself and for a while i opened up the back and manually defrosted the freezer with a hair dryer (to make it defrost faster) and lots of towels (to soak up all the water). I replaced the defrost heater in the freezer and no more problem. Go to searspartsdirect.com and put in your model # then look for the part. Hope this helps.
Posted on Nov 15, 2008
kram26
  • 544 Answers
SOURCE: GE Model # GSS20IEPA WW Fridge warm...freezer is fine
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Posted on Mar 28, 2009
bobicehouse
  • 1524 Answers
SOURCE: my fridge seems to have stopped cooling;there is condensation on the inside and the temp is lukewarm....however, the freezer is working fine, very cold.
You have a problem with the defrost timer.
Posted on Apr 26, 2009
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
I have a ge side by side dss25kgrd ww fridge. The freezer is freezing up an the fridge side is freezing the second draw. I had a service guy come an test the heater at the bottom in freezer.And said it ...
replace or first test the thermistors in both the freezer walls and refrigerator sidewall behind little plastic grilles ,they are easily tested by temp/voltage and are only $10.00 a piece,where as the motherboard is over$100.00
Mar 03, 2011 | Refrigerators
Freezer woorking ok fridge not cold model GSS20DBPC WW
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 23, 2010 | GE GSS20DBPWW / GSS20DBPCC Side by Side...
GSS201EPH WW.... Freezer is making a very loud noise. It sounds like a fan hitting. Everything works
Check to see if the condenser fan in the rear of the fridge towards the bottom isn't hitting anything. If its inside the fridge it might be ice built up around the evaporator fan.
Nov 11, 2009 | GE GSS20IEP Side by Side Refrigerator
GE side by side refrigerator(GSS22ifrf ww) not cooling
Try unplugging it for 30 seconds and then plug it in again. It may reset itself that way.
Jul 29, 2009 | Refrigerators
Fridge isn't cold
thanks,
May 28, 2009 | Refrigerators
HI,
thanks,
Mar 28, 2009 | GE GSS20IEP Side by Side Refrigerator
Side by side refrigerator problem GSH25KGRB WW
I have the same problem with my GE fridge.  I inherited the fridge with the purchase of my house.  There is a coil located in the back of of the freezer.  Remove the wire shelves and remove the screws and remove the back panel inside of the freezer.  I can almost guarantee your coil is completely iced.  I just use a hardryer to remove the ice.  I need to perform this once every four weeks.  It's a bummer.
Jan 02, 2009 | GE GSS25LGM Side by Side Refrigerator
GE refrigerator is freezing everything.
I had that problem in my refrigerator and found out that it was coming from the freezer. The thermostat in the freezer broke and it was crazy freezing in the freezer part as well as freezing in the refrigerator. Once we replaced the thermostat everything was fine. It cost me $125
Dec 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
203 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
