Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Decrease in suction
My brand new SteamVac was working fine and then in the middle of a job, all of a sudden the suction decreased significantly. The lid of the waste water tank is correctly fitted, and I have checked all the gaskets and seals. The motor is also getting hot pretty quickly. Could something have got into the motor?
    Scholar:
  • 190 Answers
Check to make sure the round gasket seal, under the hood, is in place. It is a rubber seal that sits on the plastic pipe, under the corner of the recovery tank, when the tank is placed in to the foot. It seals the vacuum from the motor, to the tank.
Posted on Oct 03, 2009
It will not pick up the water. Help !!!!!
Problem #1 - My Steamvac is not Sucking!
If your Hoover Steamvac was working properly and suddenly it is not sucking any water, nine times out of ten, the culprit is the lid on the lower recovery tank. The lid on the lower tank (or dirty water tank) needs to hinge at the front and snap down at the back in order to creat a proper seal. If the lid snaps on but is not locked on at the front, you will not get any suction. Simply take the lid off, and ensure that when you put it back on, it must hinge on the front tabs of the tank.
Problem #2 - My Steamvac is still not Sucking!
Right now you are thinking that you shouldn't have let your brother borrow your Steamvac. And you are right, because he used the hose attachment and returned it with the hose still attached to the front of the tank (some models only). Now when you try to use it there isn't any suction. In this case, you are missing your tank duct. On models where the stair/upholstery hose attaches to the front of the recovery tank, one must remove a square plastic piece in order to attach the hose. This square plastic tank duct must be replaced before the Steamvac will operate properly in the upright position. hope this helps ive copied it
Oct 09, 2016 | Vacuums
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Could the hose on steamvac be saved
The hose for this model when torn can only be replaced. With a torn hose you will loose suction from your floor nozzle, and performance will be decreased.
Aug 12, 2014 | Hoover Vacuums
Miele Silver Moon Losing Suction
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
May 02, 2013 | Miele s558 Silver Moon Vacuum
My SteamVac SpinScrub works fine then all of a sudden, the noise level of the vac seems higher and does not **** up water. I turn off vac then turn it back on, works good for awhile, then noisy, higher...
It sounds as if the ball in the tank in shutting down the suction prematurely. Be sure there is a gap of about 3/4 inch between the top of the filter inside the tank, and the lid of the dirty water tank. Without this gap, suction will pull the ball up too soon.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Decreased suction and high pitch whine in motor
clean out suction tubes ther is something caught in them
Dec 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Blown vacuum fuse?
Sounds like you got a clog in the hose, which depleted the suction. After getting clogged the motor was working overtime and burned up. If your vacuum is still under warranty you should bring it to a warranty repair center to be fixed. Changing a motor in a vacuum is almost as expensive as buying a new vacuum cleaner. So if your vacuum is out of warranty I think you should probably buy a new one.
Oct 09, 2009 | Vacuums
Doesn't pick up: No clog seen
Change your belt as it is most likely broken, it takes a standard 7,8,9 belt in a green package. Also, it is very important that you clean the foam filters in that unit at least once a month. Dirty intake filters will decrease your suction wich can lead to clogging.
Jan 17, 2009 | Bissell 3576 CleanView II Bagless Upright...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
120 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
