Question about Sony Cyber-shot DSC-W55 Digital Camera
MY BATTERY CHARGER IS NOT CHARGING THE BATTERY. THE LIGHT ON BATTERY CHARGER GOES OFF AFTER 3 SECONDS.
  • Sony Master
  • 3,866 Answers
Replace the charger is what I would advise you to dofrom this point.
You could try another battery and see if that is not the issue first.
There is only 2 things wroung here 1. the battery 2. the charging unit.
Rule out charger by purchasing new battery if that does not work purchase charger. At least you will have a extra battery folating around.
Posted on Sep 29, 2009
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Why does cordless drill charger light blink off after 3 seconds?
It could be a defective battery or it might just be normal for the charger and it lets you know its charging. Look in the manual for the tool and it should tell you why it blinks and turns off. If you dont have the manual i'm sure you can look it up online.
Feb 02, 2012 | Coleman Powermate 18 Volt Cordless Sander,...
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
Light goes on my kone but it won't work
Well first of all you may check that the charger (adapter) is working or not, you may use a volt meter to check it out or use another charger to make sure....... further you may follow the step below -
1. Remove the battery pack from Vacuum.
2. Hold down the power button for five seconds.
3. Reinstall the battery to reset the system.
4. Plug the Charger directly into vacuum.
5. Charge the battery untill the power light is solid green again and keep the vacuum on the charger for an additional 72 hours (3 days). Important: Do NOT interrupt this charging cycle.
If further you have the same problem it means it's time to change the old battery with new one.
Good Luck!!
Thanks for using FixYa!!
May 19, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
My toshiba satallite p200-1ee laptop is not charging. Battry life left: 40% When on: The Charging light blinks 3 times every few seconds and the screen dims with it. When off (But pugged into mains): the...
If you plug the charger into the computer without the battery and the laptop runs fine, then I would suggest to you that your battery is failing and will no longer accept the charge. On the other hand if the laptop will not stay running or acts strage and the screen dims and gets bright, then I would suggest to you that the charger's built in voltage regulator is failing and will damage the laptop if it continued to be used. A bad charger will also permenently destroy the battery condition.
Dec 01, 2009 | Computers & Internet
Compaq R3000
r u mention for battery light?if is it true,then the light is blinking because of your laptop want to make sure the power supply charge that battery.if it is in charging condition,the light on.but if the light goes off,that mean, the battery is already full.
But when u use adaptor without battery, the light will goes off because no charging session is in progress which has same behaviour with battery full(during battery full,no charging session occur)
May 12, 2009 | Compaq Presario R3000 Notebook
Battery Charging, Nuvi 35
Charge the unit over night, Plug in the AC charger and you should see a lightning bolt over the battery bar graph display.
With the charger plugged in, gently press and hold the on/off power until the screen goes black and displays the text "Charging battery". After a few seconds, the screen will go black to conserve power. At any time, you can press the screen and it will light up saying its still charging.
If you let it go over night, when you touch the screen, it will say Charging Complete and you can then remove the charger. You should have full green bars on the battery indicator.
- Jim
SHARCNET-USA
Dec 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
WHY WONT MY 7280 CHARGE OR TURN ON
The red light indicates its charging.  My guess is that the battery is dead and will nto hold a charge.  This is an older model phone and the lives on the batteries is 1-3 years at most.
Jun 04, 2008 | RIM BlackBerry 7280 Handheld
Westinghouse Unplugged Vacuum Turns off after 5 Seconds.
If both batteries are behaving the same way then this is probably a charger problem. When you insert the battery pack into the charger does the 'charging' light blink for 30 minutes (fast charge) then go steady? I noticed that one of my batteries was causing the light to come on steady immediately I inserted it into the charger. When I tried to use the battery pack I got the same problem everyone else is seeing, i.e. vacuum cleaner shuts off in less than a minute, so I conclude that when the charging light is on steady then the battery is not being charged.
If the charging light does not blink when you insert the battery (i.e. comes on steady or not at all), try removing the battery and re-inserting it into the charger.
Try a conditioning cycle on your battery packs. To do this:
* Insert the battery pack into the charger
* Before the charging light lights press the 'condition' button located just above the charging light.
* The 'conditioning' light should blink. This is a light which does not normally illuminate, and it is located below the condition button and above the charging light. The charger fan will run quieter in this mode.
* Leave the battery pack in the charger for 24 hours while this cycle is taking place.
I'm not a service technician so perhaps someone else might like to post other solutions or corrections to this one.
Mar 07, 2008 | Vacuums
Sony Cyber-shot  DSC-W55 Digital Camera Logo
340 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
