Question about Aspire Digital AD-150PSC Subwoofer
I have an Aspire Digital Subwoofer / Amp with no Remote
I have an Aspire Digital Subwoofer / Amp with only an On / Off switch, 5 smaller speakers, and no other way to bring it out of standby mode.
There is a web site called remotes.com that has a replacement remote for $35. http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=AD1501PSC&brand_pn=ASPIRE_DIGITAL_AD1501PSC&uuid=13715232168520
Posted on Jun 18, 2013
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Which is the best way to hook up a Subwoofer?
Last two questions first - YES, use an RCA splitter to share sub line level out between two subs and use one at the subwoofer end to share that line with both inputs on the sub.
Either attachment scheme you describe would work.
Not being a big fan of conversion/deconversion for no real purpose, I would avoid stepping the high-level input down to line level for use by the sub's internal amp, run RCA to the sub(s) and keep them physically and electrically independent of anything else unless cable routing is facilitated somehow by daisy-chaining other speakers from the sub(s).
Posted on Jan 19, 2010
Testimonial: "Thank you very much! I live in the "boonies" and it fascinates me that I can get an expert opinion online. I appreciate it."
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
My subwoofer powers on, but I get no sound out of speakers or subwoofer and all of connections are correct.
First off....never connect a speaker when the amp is on or vice versa. Second, I would get a tone generator and test that the speakers have not been ruined and check the amp to make sure you did not blow that. Most amps have a protective circuit to prevent damage from over heating or hooking up wrong. Also make sure that you have enough output wattage for the way you have them wired..
Mar 16, 2012 | Aspire Digital AD-150PSC Subwoofer
How can i pair my subwoofer to the main unit
Frequently asked questions See all FAQs Question How do I get the main unit to recognize the subwoofer? Answer Wireless connection will set up automatically when you switch on both the main unit and subwoofer.
Sometimes you may encounter the problem that the main unit does not recognize the subwoofer. Try the following process to solve the problem:
  • They are heavily interfered by other wireless home appliance such wireless network, TV etc. Move the subwoofer to another place, the main unit will auto detect & recognize it.
  • Switch off the main unit and the subwoofer and then switch on them again. The main unit should recognize the subwoofer automatically.
If neither of the above works, try to pair with them manually.
  1. In standby mode, press and hold the 090518075138_27245.gif button on the main unit (PAIR flashes on the display screen.) to activate signal transmitting.
  2. Press and hold the PAIR button on the rear of the subwoofer (You will find the LED indicator on the subwoofer flashes in blue and green alternatively) to activate signal receiving.
The wireless connection will set up automatically and the main unit should recognize the subwoofer now.
Oct 13, 2010 | Philips DC912/37 iPod Docking Shelf Bar...
My subwoofer is not working
This is due to the over use subwoofer but this can be fixed using the technician for making the subwoofer clear,but over use will make the subwoofer more complaint.
Jun 11, 2010 | Acer Aspire 8920-6048 Notebook
I have a Phoenix Gold Octane Amp and 10d subwoofers. My friend took it out last week, and I want to put it back it, but I can't figure out where the power and ground wires go and where the speaker wire...
Ok, when you look at the amp, the power + and ground - will be on one side of the amp with another smaller opening in between them. That opening is for your remote wire from your radio. Without that, your amp will not receive the input voltage to signal it to turn on. The speakers will go into the remaining open holes. Your RCA wires will be on the opposite end of the amp.
Apr 29, 2010 | Phoenix Gold Octane-R 10/10d Car Subwoofer
No sound coming out of my Onkyo SKW-200 subwoofer
A subwoofer is just really a mono amp for the signal. As with all amps if you touch the audio section/parts with a small screwdriver, you should hear a buzz from the speaker. (Follow the audio wires to be certain you are on the audio section). This can be used for testing the amp section. If you get no buzz or noise (anywhere) at all then it's power supply could be playing up. If you have a multimeter you can test it looking to see if it is getting power. Allways suspect any part that is on a heatsink. Before removing any suspect you can put the part numbers into Google to see if you can get them and it will give you a clue to cost.
PS don't short any parts when you touch with a screwdriver, and don't put it on the power parts.
Feb 02, 2010 | Onkyo SKW-200 Subwoofer
AR SW-30 subwoofer doesn't switch to standby mode when off
Disconnect its input cable to see if a true lack of signal lets it go to sleep. If not, it has a bug. Otherwise, you probably have some sort of signal present on the sub cable.
Jan 17, 2010 | Audio Players & Recorders
The woofer wont turn off
The only wires that should be going to the subs are the Speaker wire, The power, goes to the amp, Blue the remote wire should only go to the remote spot on the amp wich is usually labeled rem. and the ground all goes to the amp.
Nov 19, 2009 | Vibe CBR10 Car Subwoofer
797 people viewed this question
Top Aspire Digital Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aspire Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
