Question about Wmf/Usa 4.5qt Stainless Steel Perfect Plus Pressure Cooker
The sound of WMF perfect plus is too loud while cooking.
The sound is too loud while cooking. Is it correct to keep stove on like 5 minutes after the horn starts to make noise?
2 Suggested Answers
SOURCE: can you direct me to
Click on the link below to view the operating instructions and assembly for the WWF pressure cooker
http://www.wmf.com/wmf/upload/pdf/perfectplus_BAL_en_20070216_1904.pdf
Posted on Aug 09, 2010
How do I get the helper handle to stay on
Here is a review of the WMF pressure cooker, in the performace section (bout the middle of the review) are detailed step-by-step photos on how to get the handle on and off.
http://www.hippressurecooking.com/pressure-cooker-review-wmf-perfect-plus-rating/
Make sure that the red lever is pulled back when the handle is on and that it snaps back into place on the underside of the lid.
May 31, 2014 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
We took the pot away from the heat and let it cool. After checking that it was assembled properly, put it back on a much lower heat setting and it is fine now. It appears that the heat on this pot has
Here is a detailed description of how the pressure cooker should work. The "fog horn" should not activate until the second red ring is out of the housing.
Dec 07, 2012 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
The pressure does not build up and the valve does not rise
There are photos of the WMF handle here. Make sue it is installed correctly, and the handle is in the locking position
Apr 02, 2012 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
Valve does not rise
There is usually a safety pressure valve besides the floating valve. Make sure it is not in the release position. Push it down. Is your stovetop getting hot enough? Try using a different or larger element.
I have a 3L 22cm wmf perfect cooker which leaks, can you help?
Make sure the gasket is in the right position, the handle is placed on correctly and the slide on the handle is in the locking position. Here are more details on how to use this pressure cooker.
Aug 24, 2011 | Wmf/Usa 2.5qt Stainless Steel Perfect Plus...
Can I get a copy of Chinese user manual for Perfect Pressure Cooker?
Here are all of the pressure cooker manuals for WMF pressure cookers:
http://www.hippressurecooking.com/category/manuals/wmf/
Aug 18, 2011 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
No.1 part, the round whistle in the middle of the lid doesn't pop up when the cooker is on and pressure is building up instead the steam comes out of small pressure ball and it sprays everywhere.
Here are detailed instructions on how to use it. It sounds like the slide on the handle was not set to the locking position:
Mar 22, 2011 | Wmf/Usa 2.5qt Stainless Steel Perfect Plus...
The top and fan oven keep going off because of the timer. I dont know how to get rid of the timer a I never use it. But I donbt want it to cut out th overn which it is doing. Hel,p and info please
There are 5 buttons next to the clock. From left to right they are:-
Minute Minder, Cook Time, Ready Time, Plus and Minus.
It sounds like the timer needs setting back to manual, so to cancel the automatic setting and return to manual operation, press the Cook Time and Ready Time buttons simultaneously.
To cancel any remaining cooking time left on the clock before the alarm sounds, press the Cook Time and Ready Time buttons simultaneously.
If you are interested, to set the time of day, press the Cook Time button and the Ready Time button simultaneously. Then use the Plus and Minus buttons to set the required time.
To set the Minute Minder, press the Minute Minder button, then use the Plus button to set the required time. You can cancel the minute minder at any time by pressing the Minute Minder button and the Minus button until the display returns to 0.00.
To select an alarm tone, press the Minus button to listen to the first tone. Release the Minus button and press it again to listen to the second tone etc. Releasing the Minus button after the tone has sounded will automatically select that tone.
Hope this helps.
Dec 05, 2008 | Stoves 720EF Electric Double Oven
Wmf/Usa 4.5qt Stainless Steel Perfect Plus Pressure Cooker Logo
104 people viewed this question
Top WMF Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a WMF Kitchen Appliances - Other Expert? Answer questions, earn points and help others
