Question about HP Pavilion dv1000 Notebook
HP Pavilion dv1000 doesn't charge I charged the battery in another computer and it works perfectly, but when i use the same charger it wont charge the battery although lights indicate charging (also windows indicates charging). when the battery dies nothing will work again. The connector is fine (otherwise no lights for charging will come on) THX in advance also computer doesn't work with charger only.
  • s_zachy Oct 01, 2009
    Thx, although the bad news!
  • Rashid Mar 15, 2013
    My Computer HP type his problem but the battery does not charge batri been discharged to another computer if I put it in my computer inawika problem is exactly what I asked for help to solve this problem. I have my doubts may exist in the system for battery charging plug adapter I suggest that you go for electric lighting power indicater is showing is that entered in the computer
  • 339 Answers
You need a new system board unfortunately.
Posted on Oct 01, 2009
Testimonial: "it seems he's right "
No power on hpdv1000
You could have a broken power socket where the charger plugs in to the laptop. If the battery is flat and the socket is broken or loose then it wont charge and will be completely dead. If the socket is ok then it should power up with just the charger plugged in, even without the battery plugged in. You could also have a broken wire in the plug on the charger, the end that plugs in to the laptop.
Feb 01, 2012 | HP Pavilion dv1000 Notebook
My lab top wont charge the battery its new
Your laptop does not charge the battery, the charger plug charges the battery. Could be a bad charger or battery, just because its new does not mean it works.
Feb 05, 2010 | HP Pavilion dv1000 Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
Battery is working fine but laptop is unable to charge the battery
If the battery is definatly not faulty, and the laptop won't charge it, then I would assume the charging circuit is faulty. As they are built in to the motherboard that would need replacing.
Nov 21, 2009 | HP Pavilion dv1000 Notebook
My dv1000 is not charging. The volt meter is showing that the charging devise is working.
Sounds to me that the batteries are not seeing the charger or the battery system is bad
Jul 26, 2009 | HP Pavilion dv1000 Notebook
New battery and charger, but still not charging
Not at all. take battery and laptop to store for proper chack.
Good luck.
Rate this
Apr 13, 2009 | HP Pavilion dv1000 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
Charging cable gets hot, charge port too, not battery though
No it is not a problem. The power dissapiation in the adaptor causes it to become hot.
Jul 16, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
458 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
