Cannot get my pilot to stay lit
I get the pilot light to stay lit by holding the pilot button down for sometimes more than a minute but when i go to turn it to ''ON'' the pilot goes out. What can i do to make this start?????
    President:
  • 3,433 Answers
Make sure the thermocoupler is about 1/4 in in the flame of pilot. If it persists, as you say it is, the thermocoupler is defefective. It's that bulb in the pilot flame. Good Luck, Ned
Posted on Sep 29, 2009
New kozy world natural gas heater. Pilot light wont stay lit snd heater flame wont stay lit.
Are you holding down the pilot light button long enough for the heat sensor probe to get hot and turn on the gas valve? It takes up to 3 minutes
Nov 20, 2016 | World Heating & Cooling
Is there a pilot setting on my Honeywell gas valve for a Laars series 2 gas heater for my spa 175N
yes look at gas valve turn to pilot hold down for about a minute then light pilot generator keep holding button down for about 2 minutes then turn to on should stay lit if not need new pilot generator
Dec 06, 2014 | Pool & Spa
Have winrich perfecta ventfree lp model 6380. Very hard to start. Ignition switch never worked correctly. Pilot and ods showing corrosion. Doesn't stay lit very long. Can I replace the pilot/ods a
First clean out pilot light with can of air , or blow down it with a tude.
Then brush electrode clean with a clean paint brush ,chech to see if electrode is in the right postion to light the gas not too far away and the spark is strong , Clean thermopile head if fitted, then check thermocuople /thermopile connections are tight . see if this helps .
Oct 28, 2012 | Heating & Cooling
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
When I press down and turn the know the pilot lights but as soon as you let up on the knob to turn it there is a click and the pilot light goes out.. This is on my Mr. Heater Big Buddy
When the pilot lights continue holding the button down for a full minute and then release. It should stay lit then to allow you to turn it to the on position. If the pilot will not stay lit after holding it for the full minute, then the thermocouple will need to be replaced.
Hope this helps.
Sep 16, 2011 | Mr. Heater Big Buddy Heater
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Can't find instructions on lennox gf 8 series furnace
Does it have a standing pilot light? On new units, there is an igniter and not a pilot. But if you have a standing pilot, you will move the gas valve to "pilot" and push down the red button while holding a flame under the pilot located by one of the jets. Once it lights continue to hold the button down for a minute or so and then release the button. The pilot should stay lit. Then turn the dial to the on position. That's it.......... If the pilot won't stay lit then the thermocouple is bad and needs to be replaced.
Apr 05, 2009 | Heating & Cooling
Pilot light won't stay lit on convection heater.
replace the therocouple. next year do not turn the pilot off
Nov 24, 2008 | Clairion Convection Heater - HC-1500
Pilot light will not stay lit
is it full of dust my hot water used to do the same till i blew the dust and fluff out
Nov 18, 2007 | Heating & Cooling
Heating & Cooling Logo
191 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
